Beovision 5 forgets sound settings
MrChriZ
Posts 3
MrChriZ Posted: Mon, Dec 23 2013 4:59 PM
I have a Beovision 5.  Everytime the TV is turned off the sound is reset to 48 which is very loud.
Loudness also defaults to on.
Is this default behavior for this TV, or is there some internal small battery somewhere that needs replacing or something similar?
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, Dec 24 2013 9:02 AM
Is this a newly obtained TV or have you had it a while and it's always done this, or is it a newly developed 'problem'?
Have you adjusted the volume settings in the menu?  48 would be loud as about 34 is ample for me with mine!
Dave.
AT
Budapest, Magyarország
Posts 235
AT replied on Wed, Dec 25 2013 9:23 PM
On the former MX series You can, and You have to STORE the default sound setting, IMHO You have to do it on a BV5 too. Simply set Your preferred sound settings (for power on default) and press "SOUND"+"STORE"+"STORE" on Your remote.
I hope this helps :)
hfat
Vienna, Austria
Posts 663
hfat replied on Thu, Dec 26 2013 11:34 AM
Hi mrchriz,
your BV5 shows the correct behaviour as it reverts to default sound settings after stand by.
You have to set up the sound settings to your needs:
turn on BV5 and press menu on your Beo4
select option set up
select option sound
set up sound to your needs
confirm pressing go
exit menu
theese settings will be activated after stand by
hfat
Page 1 of 1 (4 items) | RSS
