Hi everyone
As a fan of doing things right the first time, I am seeking some help with recovering Beovox S75 and S45.2 frets. I have searched around the site and found a few threads with steps to recover M70's (thanks Rich) and CX series (Leslie has done EVERY colour), however the M70 frets can be laid flat on a table with the material stretched out, and the CX frets are quite small and seem to only have one angle on the front.
The 70's S series frets for my S45's and S75's are made of plastic (or similar material) and have a bend in the middle which gives them that sexy profile. What is the best way (once I have obtained a suitable fabric) to attach the new fabric.
I was thinking I would stretch it out on a table, use a spray glue on the front of the frames and top corners and then start from the top corners and adhere it down the front on the upper portion of the panel, flip the panel over and then do the lower portion, if we try to push the panels flat they will snap in the middle so thats not an option. I dont want to end up with the fabric not following the curve of the panel correctly.
Any help or pictures (we all love pics) would be great!
btw Leslie I think I might go for a nice grey for the S75 instead of white...
Drew
Hi Drew,
This is easy. I redid my two pair of S 75 speakers as well as the S 45.2’s and they turned out great.
Søren has a great piece on this with step-by-step photos.
I was just told dinner is ready, so have to run, but I posted a thread on this and Søren also suggested a source for the fabric, which was FANTASTIC!
If you have trouble finding the tread or Søren’s piece, let me know and I find them for you tomorrow.
Jeff
Beogram 4000, Beogram 4002, Beogram 4004, Beogram 8000, Beogram 8002, Beogram 1602. Beogram 4500 CD player, B&O CDX player, Beocord 4500, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 5000 T4716, Beocord 8004, Beocord 9000, Beomaster 1000, Beomaster 1600, Beomaster 2400.2, Beomaster 2400.2, Beomaster 4400, Beomaster 4500, Beolab 5000, Beomaster 5000, BeoCenter 9000. BeoSound Century, S-45.2, S-45.2, S-75, S-75, M-75, M-100, MC 120.2 speakers; B&O Illuminated Sign (with crown & red logo). B&O grey & black Illuminated Sign, B&O black Plexiglas dealer sign, B&O ash tray, B&O (Orrefors) dealer award vase, B&O Beotime Clock. Navy blue B&O baseball cap, B&O T-shirt X2, B&O black ball point pen, B&O Retail Management Binder
Hi Jeff
This is the one I found, but its not about the S series with the curved plastic grills, rather the older wooden grills. http://archivedarchivedforum2.beoworld.org/forums/t/42235.aspx
If you or anyone else can post a more suitable set of instructions about the 70's S series would be greatly appreciated.
Regards
Spray glue is fine.Just keep the glue at least a cm or two away from the speaker cutouts or they will show through the fabric.
Here is a thread for wooden frets, for the angled plastic frets I would do it in 2 steps, place your fabric on a table so it fits the upper part, cut big enough to wrap around to glue inside, the fabric for the lower part let hang over the table edge, spray the upper part with glue, place the upper part on the fabric wrap the fabric in place and make sure it is glued well into the corners, now turn the fret around, fold the fabric for the lower part to the upper part, cover it, spray the lower part, place the fabric on the table, holding the fret vertically at the table edge, keep the fabric stretched with weights, turn the fret carefully to horizontal pos. and press it to the fabric, wrap and check the corners, cut off over standing fabric, evt. strengthen the inside corners with Arleens Tacky glue, let dry until glue is clear.
Andrew: Hi Jeff This is the one I found, but its not about the S series with the curved plastic grills, rather the older wooden grills. http://archivedarchivedforum2.beoworld.org/forums/t/42235.aspx If you or anyone else can post a more suitable set of instructions about the 70's S series would be greatly appreciated. Regards Drew
Søren was so good as to provide a link to his article, which is beyond helpful. Follow his advice and you can’t go wrong.
Like you, I was concerned about the corners with the plastic curves, but the fabric just stretches around it.
The whole process looks intimidating, but isn’t.
I think the key is the proper place to do the work as you don’t want to be using spray glue in the house.
Also, Søren came up with a great idea, to mask the spray area so only the part you want sticky will be. Works like a charm.
Now Søren and Rich delight in choosing wild fabrics to express their personalities while I choose to reproduce the original factory appearance…. the choice is yours. The only consideration is the openness of the weave, as you should avoid a truly dense material which will muffle the sound.
The cloth I chose (as per Søren’s suggestion) looks solid, but under bright sunlight you can actually see the speakers behind it….. this material is being sold specifically as speaker frets. This really black cloth most certainly was a clone to the original material.
Anyway, as I see you have found Leslie, I am sure he can find you exactly what you want.
See photo of the finished S 75's and a lone S 45.
All the best!
astormsau:recover M70's (thanks Rich)
Dom
2x BeoSystem 3, BeoSystem 5000, BeoSystem 6500, 2x BeoMaster 7000, 2 pair of BeoLab Penta mk2, AV 7000, Beolab 4000, BeoSound 4000, Playmaker, BeoLab 2500, S-45, S-45.2, RL-140, CX-50, C-75, 3x CX-100, 3x MCL2 link rooms, 3x Beolab 2000, M3, P2, Earset, A8 earphones, A3, 2x 4001 relay, H3, H3 ANC, H6, 2014 Audi S5 with B&O sound, and ambio
