XML for Generation 3 Apple TV
This post has 7 Replies | 0 Followers
Amazone
Netherlands
Posts 187
Amazone Posted: Wed, Jan 15 2014 10:51 AM
I'm currently working on an XML for the Generation 3 AppleTV, based on the Apple Remote XML that's included with Config Tool 6.00.
I'm almost there know, but two commands are missing from the base XML.
They are:
Press-and-hold-Menu, which should bring you back to the main screen in one step and
Press-and-hold-Select/Go, which should bring up a pop-up, enabling you to enter language and subtitle settings during playback in the Netflix App.
Especially the latter is a pity, since I cannot find another way to enter these settings in Netflix.
I would appreciate very much when somebody could help me with creating the correct IR code for these two commands.
Kind regards,
Joost
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
PapaJustify
Posts 110
Why do you make your own .xml if there is an Apple TV in Config Tool?
Amazone
Netherlands
Posts 187
Amazone replied on Wed, Jan 15 2014 3:15 PM
That's because I now have a much more integrated solution.
The Apple Remote in the Config Tool is located under Scenes, and not visible as a separate Product in your Room. And with the Beo6 in Apple Remote mode, I still want to be able to control the Volume from my TV, which is not possible with the original XML, for example.
With my XML, and Beo6 in TV mode, I have an extra button AppleTV, which switches the TV to HDMI1, triggers the Apple TV, and shows a new menu with new hardkeys on the Beo6. But the Volume still triggers the TV. So I can adjust the volume of the music or film I'm playing. And when exiting the Apple TV menu, the TV returns to TV. You can build very nice things with the Beo6.
But also on the original XML, the pres-and-hold actions give no response so my question is still the same...
I am missing the IR for:
hfat
Vienna, Austria
Posts 663
hfat replied on Wed, Jan 15 2014 4:32 PM
Is your TV a BeoVision?
If so, do you control it via PUC?
hfat
Amazone
Netherlands
Posts 187
Amazone replied on Wed, Jan 15 2014 8:31 PM
No the tv is not a beovision and I control both TV and AppleTV directly via IR, not via PUC.
Regards,
Joost
Solex
Netherlands
Posts 103
Solex replied on Thu, Mar 5 2015 12:04 PM
I have an old Apple TV3 xml file, dated 18-04-2013 and is not working very well.
I wonder, is there a newer XML-file for ATV3 and if so, can someone sent me this xml?
Thnx.
Beovision 10-46, Beo6, Beosound 5+ Beomaster 5, Beolab 12.2, Beolab 12.3, Beocom 6000
Solex
Netherlands
Posts 103
Solex replied on Tue, Mar 24 2015 6:59 PM
Have it, so problem solved
Allhassan
Posts 1
Allhassan replied on Thu, Mar 15 2018 1:06 PM
Hi
Can you please send me this XML file for Apple tv 3?
Page 1 of 1 (8 items) | RSS
