Infra-red eye wiring for BeoSystem 1
bkanani2014
Posts 5
bkanani2014 Posted: Tue, Jan 21 2014 5:22 AM
I have a system one that I need to re connect the active IR eye wiring.
I found this link in Beotech section but it shows it with 7 connection and mine has only 5:
http://www.beoworld.org/beotech/ir_eye_wiring.htm
I need help reconnecting the wires back into their correct slots.
There are 3 main wires that were in the right 3 slots. Yellow, Green and Brown/red. There are also blue and white wires but I don't think they matter. During a recent move they accidently were pulled out of their correct slots so now my system one remote does not work and system one doesn't go on. Can anyone tell me which wire belongs to which slot?
Thank you!
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
I think the following diagram is what you are looking for
Regards Keith....
expoman
Posts 182
Silver Member
expoman replied on Tue, Jan 21 2014 5:42 PM
That is the Beosystem 2 guide I believe,the Beosystem 1 is different as it never had an auto contrast feature.  I believe this is the correct diagram.
expoman
Posts 182
Silver Member
expoman replied on Tue, Jan 21 2014 5:48 PM
The bottom three terminals are the only ones used. With the terminal strip to the right,  Bottom Brown, next Yellow next Green.,  These are from the three wire cable with a headphone jack.
bkanani2014
Posts 5
Thank you! Thank you! Thank you!
It worked!
Page 1 of 1 (5 items) | RSS
