Carelessly I have taken the speakers apart, and disconnected the two wires that goes to the connector block in the middle. I did not pay attention to which wire goes to which connector. One of the wires is green, the other is black. The connector has a black tab and a red tab. Does black wire go to black tab, and green wire to red tab ?
Kent
To which driver goes the wires
I should have been more clear, sorry. I am referring to the wires that go from the filter PCB o the external connector block, not the wiring to the drivers. I'm assuming the speaker will be out of phase if I get it wrong.
A black wire is also connected to the wide pin on the DIN connector on the side and a green wire is connected to the round pin on the DIN connector. I'm going to assume that the green is the signal wire, and black is ground. .
Maybe this could help?
Brengen & Ophalen
Green to red, black to black.
