Hi Guys just trying to connect my iphone 5 to my tv but i cant seem to find headphone socket ? also does anyone know how I can just play the music on the tv what channel etc ??
The headphone socket on the TV is in a concealed panel on the rear of the TV near the left hand side (when viewed from the front of the TV). Push the panel to open and again to close.
However, this is for connecting a pair of headphones to the TV not for connecting an iphone or similar as an input. To connect your iphone you will need a cable from the iphone to the two phono connectors (red and white) in the same panel as the headphone socket on the TV.
Kind Regards,
Oh, and to listen to the iphone once you have connected it to these inputs you will need to press LIST on the beo4 until CAMCORD is displayed and then press GO.
Martin.
Thanks so much will try now !!
