Looks fine - and the CD4 PCB!
Click here
cant see cd4 board mentioned and no light. you asked the seller?
The CD4/OFF switch on the side has been fitted to about 50% of the Beogram 4002s produced.Don't take it as a guarantee that the board has been installed.In most decks the switch is not connected to anything.In some decks the holes for the switch are empty, merely covered by a small black label.Others don't even have the holes.
Of course, I forgot about that.
I've emailed the seller - I'll update with a YES or NO.
Edit:
The seller has confirmed that it is ONLY the switch, not the PCB.
But it's cool that I can still get excited over things like this, even if just for a moment!
