Beosound 5 encore, beogram 4500 and beolab 6000 and Almando power link switch
Paul cheacker
Spain
Posts 130
Paul cheacker Posted: Mon, Jan 27 2014 8:59 PM
Hi I want to be able to connect these together, now I know this is not possible via the beosound 5 encore as its a stand alone system. However ive stumbled across this almano power link-switch stero. My question is this however as the beogram 4500 has a built in RIAA will this set up work and how would I control the volume! Does anyone have any experience with this company. I've sent serval emails but as its a German company they do not understand my questions.
Current b and o Products
beosound 5 encore, beolabs 6000, beogram 4500, playmaker mk1
Millemissen
Flensborg, Denmark
Posts 14,680
Best thing to do is to buy a Beomaster 4500 to connect the BeoGram.
Then connect the BM and the Encore to the switch
If you put the BM in Option 4, you could even remote-control it (and the BeoGram) using the 'Link' command before you push 'Phono'.
Paul cheacker
Spain
Posts 130
Ah never thought of that thats not a bad idea thks
riverstyx
SouthWest UK
Posts 938
riverstyx replied on Tue, Jan 28 2014 12:09 AM
Hopefully I'm not missing something obvious, but since the Beogram 4500 has a RIAA preamp it's output is at line level and the encore has a line-in, so surely all that is required is a suitable cable to connect the two together?
Martin.
Millemissen
Flensborg, Denmark
Posts 14,680
Hi Martin,
no - you are not 'missing' anything.
That would be a very slim setup.
Why didn't I think of that Unsure
Eddegroot72
Posts 58
I use the almando switch for connecting my encore and my loewe tv to beolab 18
If you can connect the Beogram to the line in in the encore (3.5mm jack) there is no need to buy the almando.
however keep in mind that the line in on the encore is situated kind in the front of the encore in stead of behind it. So your cable will be visable.
regards, Edwin
Paul cheacker
Spain
Posts 130
Ah thats a great solution, I can then plug it in only when I want to use the beogram 4500
thanks all.
Page 1 of 1 (7 items) | RSS
