BeoGreg:Once in a while, I have to press twice the remote to get access to TV or DTV. The green light flashes a second than nothing, a dark screen without sound or picture and without the B & O logo. I press a second time and then everything is ok. Am I the only one here ?
I had something similar with certain TV channels. It resulted in blank recording to the hard disk (discussed in another thread). The answer with the TV channels was to retune the TV from scratch, after which the problem disappeared.
I sometimes get a No Network message on DTV and no home page, even though the router is OK and i can call-up YouTube and Spotify from the main menu and they will work.
The picture mute for radio stations will only work if I change between radio stations... it does not work when switching from TV to radio. this is a long-standing issue, reported to Struer. Seems that there are still plenty of bugs to be sorted out.
Graham
Also happens to me sometimes that the TV won't switch on and I have to press the TV button a second time. Also the no network problem is there, but only if I am already in a web media smart app and want to go back to the smart apps main page.
I think, the software has still a lot of flaws and I am also disappointed about the very basic implementation around the built-in hard disk recording. Don't know why they can't fix/improve the software more quickly, there are many excellent programmers in India or Eastern Europe that are inexpensive.
schatzoy:Also happens to me sometimes that the TV won't switch on and I have to press the TV button a second time. Also the no network problem is there, but only if I am already in a web media smart app and want to go back to the smart apps main page.
BeoGreg:Exactly my case ! Please take note B&O.
