Hi
This post has 9 Replies | 0 Followers
Posted: Sat, Feb 15 2014 10:17 AM
Hi
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Based on your "Problem Statement" and in particular the fact that your standby light flashes when you press the buttons on the remote tells me that you have an intermittent hardware fault which has become permanent in the power supply control circuit or some fault triggering a no switch on signal.
There are many reasons for the power supply not switching on out of standby, but in most cases its a safety measure due to a fault somewhere in the chassis and you are going to need a knowledgeable engineer to do some voltage checks to establish the actual fault. If you get a B&O engineer to come and fix it they will replace the whole chassis, rather than look for the faulty component.
Regards Keith....
replied on Sat, Feb 15 2014 3:44 PM
Thankyou
replied on Sun, Feb 16 2014 7:45 AM
thanks
replied on Sun, Feb 16 2014 7:46 AM
it's in perfect condition apart from what was mentioned
bramble
Posts 397
bramble replied on Sun, Feb 16 2014 12:24 PM
Had the same issue with my bc1, told it would require a new power supply board! Result ....wrong b&o advised they no longer had these parts sadly of to the tv graveyard ,
Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
replied on Mon, Feb 17 2014 7:49 AM
Managed to fix it
replied on Mon, Feb 17 2014 9:44 AM
thanks
jlpmolenaar
Posts 31
I had the same problem with my Beovion 1 type 8610. I tried everything to turn the thing on with no result. The dealers conclusion was that the Eprom and processor on the main board where not function. They had to be replaced. Unfortunately the processor cannot be ordered anymore from Bang and Olufsen, so the Beovision 1 is RIP.....
bramble
Posts 397
bramble replied on Thu, Sep 4 2014 9:22 PM
When my bv 1 gave up I.e power supply, I sold as much of it as I could
The contrast screen
Speakers
Stand
Case
In the end all I had left was the CRT , I hated to do it as it looked great! but if it ain't going to get fixed Sad
it becomes a parts department Wink
Page 1 of 1 (10 items) | RSS
