Hi Everyone
I have no idea what I've done.....Disconnected my BS3000 for half an hour to give it a good clean, and when popped the unit back and re-connected the ML and mains cable, didn't fire back up with Beo4 on pressing 'CD'. Worked on manual though - using the kepad on the stereo.
So I turned everything off (BV1 and BS3000) and re-set the BC1 to option 2 and BS3000 to option 0 using Beo4 seeing the confirmatory red blink on both units. Pressing CD won't start the stereo nor SAT start the BC1.
So I've put the BC1 on option 1 so I can use the TV until I get any clue as to what is going on!!! The standby lights are red so happy the BS3000 is not on timer mode (never used this function).
Any ideas anyone?!
Thanks in advance
Regards
Jonathan
