Hi Räuber,
congrats to your new sub
I doubt that there will be a SW-update for that.
Why not try out both - play around a little and see/hear what suit you best in your listening conditions.
Greetings Millemissen
Raeuber:Before I will go for Beolab 19 I will first test it with my Beolab 1 (because lack of ba
Is this your first sub ?
Looking forward to your Bl19 results, enjoy
valve1:Is this your first sub ? Looking forward to your Bl19 results, enjoy
Great - I had not expected that.
They have a lot to do in Struer!
I often wonder how these few (there aren't that many) guys can manage everything.
B&O setups are very complicated - every software change has to be tested in a lot of constellations before they are released
Hi Raeuber !
Latest software for your BeoVision 7-40 MK VI : is Build 1112 .
But it is no correction about beolab 17 18 19 in it. Only soft fix.
/*talisman
talisman:Hi Raeuber ! Latest software for your BeoVision 7-40 MK VI : is Build 1112 . But it is no correction about beolab 17 18 19 in it. Only soft fix. /*talisman
Raeuber:I have just asked a technician from B&O. He told me that B&O would recommend to select Beolab 3 (not 2!) if connecting BL 19 to BV 7.
This is incorrect. You should select BeoLab 2.
The "BeoLab 3" recommendation originates from a typo in a rather large lookup table that was sent out. It was corrected very recently (a couple of days ago give or take...) and I don't know if the new version of the table has been distributed out to the dealers yet.
Also note that you should set the BL19 to "L+R" mode on its selector switch. If you do not do this, you will be 6 dB low on the output.
cheers
-g
geoffmartin:Hi, This is incorrect. You should select BeoLab 2. The "BeoLab 3" recommendation originates from a typo in a rather large lookup table that was sent out. It was corrected very recently (a couple of days ago give or take...) and I don't know if the new version of the table has been distributed out to the dealers yet. Also note that you should set the BL19 to "L+R" mode on its selector switch. If you do not do this, you will be 6 dB low on the output. cheers -g
