Hi to all,
I would to ask somebody to help me with my Beocenter 3600. It is in very good visual condition but the functionality is worse - so I gave it to a repair service here in Prague/Czech republic, but they are not able to repair it because of having not the right components/parts. They gave me list of parts which thay need to change/replace and said it is atypical b&o part which are not able to buy in Czech...
Can anybody help me with it? Where can I buy this parts
here is the list from service:
Welcome to Beoworld !
Are you sure about it being a Beocenter 3600 ?The component designators and partnumbers you list, doesn't match very well with Beocenter 3600.
Thank you for reply
yes it is beocenter 3600 - I try to search those partnumbers in manuals for bc 3600, bc1800, beomaster 1100 and didn´t find match, so i try to ask here...
I must to ask once more in service if they did not make a mistake... (I had there half year before defect Beocenter 7002 for diagnostics so this list can be for it)
But otherwise - is it possible to buy somewhere replacement for special (atypical?) b&o parts for this beocenter (like bad transistors) ?
Thank´s
Ondrej
I can supply most of the electronic parts, some new, some used original parts.Try to find the correct list of needed parts.
