lonfred:Hi I have been waiting for a while that video option 6 should be available in a V1 or BV11 conected to ML by NL/ML converter. Does anyone know if this will happend and if when? I would like to buy a V1 or BV11 for a link room and use a BV10-46 MKII as master. Since I also have two BV6-23, one 6-26, one 8-32, and one 7-32 as Link room TVs it would be no option for me to change the video master to a video master without RF-out like the V1 or BV11. Perhaps someone know if it soon will be possible?
Bv11 or v1 would never have option 5 or 6 but that is no problem (for sound) you can use them in linkroom in option 1 or 2 together with ML based Product to get sound from ML master but you cannot get access to videosources from videomaster, the new NL based Product does not have audio/video master setups and you can take sound in both way on NL
Posted some time ago so maybe you get answer already maybe?
BC2 will work as audiomaster in NL/ML setup and also beoport if you have an audiomaster for.eksample BC2 also radio function will work
/Tompa
