Got a problem with a Beogram 4002.
When switched on it starts on 45 by default. Then on switching to 33 and then standby, it starts on 33 as normal.
However, when turning off at the mains it switches back to 45. Is there a component on the speed control circuit that might be the issue here?
Many thanks
Ben
Hi Ben:
I suspect the capacitors in unit have gone bad and causing the quirky behavior.
List member Graham might be able to help you fix it if you live near him.
Derek
In some versions, the condition of the lamps for the speed indicators are essential for correctoperation of the speed switching.A broken (or wrong wattage) lamp may cause problems.I've seen it a couple of times myself and Tim also noted it (bottom of this page):
http://notebook.beocentral.com/page/6/
Many thanks to you both,
Will look into this. Thanks also for the new belt Martin, arrived today.
