Hello have a Beocenter 9000 and need your help with it. When I turn on the CD player sounds like FM radio with bad reception. CD plays the music and you can hear but mixed with a lot of noise and interference, which after the Big Bang. I changed the whole CD The mechanism with one that I know it works but I did not help.
Regards
Jan
Sounds like a decoder board fault, allowing all read data though to the DAC.Normally, you won't hear the track/frame data, only the programme info.Check for cracked solder joints at the decoder board (that's the board at the bottom of the Beocenter, not theservo board at the underside of the CD drive).Still no luck, replace the board.
Could also be a missing voltage but if everything else is working fine, I would try the above.
hello martin, decoder board, I had also changed just forgot to write this. decoder board swapped did not help. If I have time I'll look at Beocenter 9000 again today and will be returning.
