I'm looking for a DVB-S modul for my mkIII beovision 7-32.
I saw this on ebay: http://www.ebay.de/itm/Bang-Olufsen-DVBS-Modul-BeoVision-7-40-Nachrustmodul-/301126791177?pt=DE_Haus_Garten_Inneneinrichtung_TV_M%C3%B6bel&hash=item461c8e3009
Know if can I mount it on my TV?
Regards.
Which channels do you want to watch?
lots if channels are using DVB-S2 instead of DVB-S. DVB-S2 is using mpeg-4 to stream HD content.
So, before mounting any kit, I would investigate if it will work.
Any recent settopbox (also in small packages to mount at the back of a BV7) supports mpeg4 and most likely supported in the puclist.
I have the TV in the place where there is little DVB-T signal.
In Italy there is a satellite card named "tivùsat" (http://www.tivusat.tv/pages/prodotti/149/0/0/Prodotti-certificati-tivusat.aspx) with which you can watch all DVB-T channels, through satellite.
