Beogram 5005 and MMC4: dull sound
This post has 50 Replies | 2 Followers
chartz
Burgundy, France
Posts 4,171
chartz Posted: Sat, Mar 29 2014 1:02 PM
So I've got that mint Beogram 5005, really in perfect condition. It works perfectly.
BUT the sound is dull, dull, dull - on both channels.
Rich sent me his spare MMC4 for testing (thanks again Smile) but even though it sounds much better that the refurbished MMC4 that I sent over to Germany - more bass, nicer overall sound with better tracking ability -treble is still lacking. It is really recessed, as if it went down right after 8 kHz or so. It is not warm, it is boring.
I inspected solders, contacts. I saw nothing.
Jacques
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Sat, Mar 29 2014 1:07 PM
Problem with the RIAA phono preamp? Can you get a hold of a different phono preamp and run it thru that and into an aux in rather than phono in on your receiver?
Jeff
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, Mar 29 2014 1:11 PM
Jeff:
Thanks.
Same results with different preamplifiers, unfortunately. Hence my query.
Jacques
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Mar 31 2014 5:26 PM
Any ideas then, please? Sad
It's a shame because my otherwise superb Beosystem 5500 is great, but is let down by its turntable. Plugging my Beogram 4000 in its stead makes vinyl sing though, with plenty of energy!
Jacques
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Mon, Mar 31 2014 5:48 PM
Well, one of the things that can affect a cartridges sound is vertical tracking angle, though usually that's a fairly subtle change. And anyway, the B&O design with integral cartridge/arm design means that's pretty fixed and should be right by design. It's with conventional arms and different cartridges you need a height adjustable arm to set VTA.
The only other thing I could say is the wiring from the cartridge all the way to the DIN connector or RCA plugs. Cartridges are sensitive to things like resistance and capacitance, but unless there's a defect or someone radically changed or mucked about with the tables wiring that shouldn't be it either.
Maybe the arms tracking force gauge is way off? Check it with a stylus force gauge?
Jeff
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Mar 31 2014 6:04 PM
Thanks Jeff.
Checked with a gauge. Spot-on.
I checked everything, contacts (golden anyway), wiring, DIN shiny new. The deck is really nice.
Jacques
Orava
Finland
Posts 991
Orava replied on Mon, Mar 31 2014 7:01 PM
Muting switch?
On second tought, cant be switch, unless it is somehow leaky...
R,C or Z related problem? From connecting cable? You could try different cable.
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Apr 1 2014 2:57 PM
Orava:
I get all that (being an electrician) but the cable is the original one, and its capacitance is within normal values.
Perhaps I should try another one indeed, from some scrap unit?
The switch was not muting anything when I got the deck, I had to play it a lot to get it back to its grounding duties.
Jacques
Orava
Finland
Posts 991
Orava replied on Tue, Apr 1 2014 4:42 PM
Could switch then have extra capacitance build......?
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Apr 1 2014 5:12 PM
Orava:
Mmm... how could that be? Deliberately? When it's open-circuit, there is no contact whatsoever. If anything, extra-capacitance would brighten it up around 8-10 kHz.
I just don't get that one really. Is the MMC4 a dull cartridge after all?
Jacques
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Tue, Apr 1 2014 8:30 PM
chartz:
Having lived with at least one continuously for at least 24 years, I would say no.
Søren Mexico
Mexico City
Posts 6,411
I have an original, bought used, not dull, and a SMMC4 brighter, more like CD sound but not dull
chartz
Burgundy, France
Posts 4,171
chartz replied on Tue, Apr 1 2014 9:04 PM
So there must be something wrong with my 5005. But what?
Jacques
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Tue, Apr 1 2014 10:39 PM
Any chance of a recording of this poor sound quality? Preferably a direct recording.
Lee
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Apr 2 2014 5:57 AM
It crossed my mind. I could do that, yes.
I will do that on Saturday then. Any favourite music?
Jacques
Lee
Posts 734
Lee replied on Wed, Apr 2 2014 3:24 PM
chartz:
Its often easier to diagnose a problem if we can hear it... Describing sound issues is very subjective.
Hmm favourite music... now that's got me thinking ;-) A nice bit of classical, perhaps some Rachmaninov? But to be honest you'd probably be better with some pop music... I always find Abbas good for diagnosing excessive Sibilance etc and I know exactly what they sound like on my 5005 with MMC4.
Lee
Lee
Posts 734
chartz:
Lee
joeyboygolf
Ely, Cambridgeshire, UK
Posts 4,188
I listen to loads of Axel rebuilds and I cannot distinguish them from the original MMC4's.
I find both types quite comfortable to listen to and I would not want them any brighter.
My BG6000 is fitted with a NOS MMC20CL which is comparable and was very similar to an Axel rebuilt version which I sold to a French Beoworlder who thought it was fabulous.
Regards Graham
chartz
Burgundy, France
Posts 4,171
chartz replied on Wed, Apr 2 2014 7:22 PM
I know! I also have a 20CL on my 8000 and an SMMC20EN on my 4000 and the poor 5005 with MMC4 sounds dreadful. It tracks very well though.
Jacques
Orava
Finland
Posts 991
Orava replied on Thu, Apr 3 2014 11:08 AM
chartz:
Orava:
I mean, if there is capacitive leak to ground, that would ..... "anti-brighten" sound?
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 1:57 PM
My experience is just the opposite actually. I can't measure anything conclusive, anyway. Capacitance is in good order.
Jacques
Orava
Finland
Posts 991
Orava replied on Fri, Apr 4 2014 2:34 PM
Ok Smile, just a tough
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 3:51 PM
Here you go.
There is a sample of the sound! Not very good at all.
Jacques
Rich
Posts 2,598
Rich replied on Fri, Apr 4 2014 4:06 PM
chartz:
Here you go.
Sounds fine to me.  Can hear the high hat cymbal right of center, female vocals sounded fine.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 4:12 PM
Rich:
chartz:
Here you go.
Do I need a hearing aid? Sad What's wrong?
Jacques
Rich
Posts 2,598
Rich replied on Fri, Apr 4 2014 4:18 PM
Do I?Huh?
I'll listen at home after work again on one of the home systems and comment again.
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 4:40 PM
Thanks for bothering at all Rich!
I compared to the iTunes version - I don't have the CD - and it hurts even more...
Here's another version to compare. Cruel!
Jacques
Lee
Posts 734
Lee replied on Fri, Apr 4 2014 5:15 PM
chartz:
Here you go.
That does sound a little flat to me too...
I'll connect the PC upto my Beomaster 5000 and do a side by side comparison with the same record playing on my Beogram5005 and MMC4 and get back to you...
Lee
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 5:20 PM
Hi Lee,
I did the right choice then! Stick out tongue
Thanks!
Jacques
joeyboygolf
Posts 4,188
The first version is the one that I am used to.
The second version is something that I would prefer but I have no idea how to achieve it. Much better, full of life and vitality. Sounds like a different mix or pressing!
Whatever produced it , I want one!!!
Regards Graham
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 5:56 PM
joeyboygolf:
It is the CD version I managed to borrow.
Jacques
tournedos
Finland
Posts 7,357
Rich:
chartz:
Here you go.
Sounds fine to me as well.
The second version - aside from being much louder, which always kills a direct comparison - sounds to me to be the remix you will find on Spotify for example. I hate it, it's totally in your face and void of nuances.
--mika
Rich
Posts 2,598
Rich replied on Fri, Apr 4 2014 6:10 PM
chartz:
joeyboygolf:
Boy, I really wish you hadn't posted that already.  I was going to say "loudness wars."
I think they sound essentially the same if you level-match.
Rich
Posts 2,598
Rich replied on Fri, Apr 4 2014 6:11 PM
tournedos:
Rich:
chartz:
Here you go.
Which begs the question, do I want to invest in the new versions of Led Zeppelin's first 3 albums?
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 6:12 PM
If it really does sound fine, well I'll have my ears checked! But thanks for the comments.
Seriously, the same record on my Beogram 4000 sounds amazingly better. It is much closer to the second version, minus bass slam.
My LP is an original French first pressing.
Jacques
joeyboygolf
Posts 4,188
chartz:
joeyboygolf:
It certainly doesn't sound like my CD version, which sounds dull and flat by comparison.
Mine is an early CD purchased when they were first issued and sounds almost identical to my vinyl version, also early.
Regards Graham
Søren Mexico
Mexico City
Posts 6,411
I run the first version through my computer to Onkyo to Bvox 3702, running flat, bass on "0", treble "0", it do sound dull, raising bass 10 % and treble 30% I get the sound I like, cymbals coming out clear and bass OK, the second version is awful.
On the Onkyo I can switch between different sound modes, In "Direct" (sound in is the same as sound out, no modifying) its dull, changing to "Stereo mode" bass and treble "0", its dull, with bass 10% and treble 30% it OK
Well my hearing is shot after many years in noisy environments. Normally I run my TX2, MMC4, in this setup and in "stereo" and bass 5% treble 10%
tournedos
Finland
Posts 7,357
chartz:
If you can compare them directly, then I'm not questioning that. I was just saying that I don't find anything obviously wrong in the first sample. It's really hard to say because sadly I don't have the original recording of "Rumours" on any media, but I do know that it was ruined some time in the later releases.
So I don't have a direct reference to judge your first sample (the second is useless for that). But anyone used to the second version will think the original release sounds dull, even when everything is fine!
--mika
chartz
Burgundy, France
Posts 4,171
chartz replied on Fri, Apr 4 2014 7:46 PM
Hi Søren,
So we agree.
I don't get that with the Beogram 4000 at all. This LP sounds superb on it, not so on the MMC4-equiped 5005.
The 30 percent treble increase sounds about right.
Mika,
Trouble is, any LP I care to play is dull-sounding. Not so on my Beogram 4000! Even an old Dual 601 with an old Ortofon FF15 sounds better.
Jacques
Rich
Posts 2,598
Rich replied on Fri, Apr 4 2014 11:32 PM
Well, I listened at home on a "good stereo" and I haven't changed my opinion:  the first recording sounds fine to me.
I feel like I'm in some kind of "Emperor's New Clothes" fairy tale, or the classic Harvard University peer pressure experiments in the 1950's.
Page 1 of 2 (51 items) 1 2 Next > | RSS
