Wonder if anybody can suggest a solution please for an issue with the cassette deck on a 2200 which is in otherwise perfect order and is highly treasured by my father! As soon as play is selected, a high frequency squeal is emitted from the speakers, which changes frequency when the tape bias switch is moved. No other audio can be heard.
I suspect bias osc filter circuit, but to save a lot of poking around I'd be grateful for anybody with practical experience of the unit to offer advice.
Thanks in advance.
Interesting.The bias osc should'nt be active in playback of course.It seems as though there is some problem with system switching?
There are some capacitor issues with the record/play circuit,but this may be due to a faulty record/play reed relay,or it's control.Electrically these little Centre's are proving to be very long lived,considering their complexity.
Worth checking further indeed.
Whereabouts are you sir?
Nick
The bias osc. is at a very high frequency, 80-100 kHz which is impossible to hear as no generated tones can create harmonics lower than the base frequency.
A more possible answer would be a capacitor fault.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Poor grounding somewhere, tapeheads maybe.
Hi Nick, thanks for the reply, the unit is in Lancs.
