Beocenter 2200 Cassette Problem
Dish
Posts 2
Dish Posted: Sat, Apr 14 2012 11:54 AM
Wonder if anybody can suggest a solution please for an issue with the cassette deck on a 2200 which is in otherwise perfect order and is highly treasured by my father! As soon as play is selected, a high frequency squeal is emitted from the speakers, which changes frequency when the tape bias switch is moved. No other audio can be heard.
I suspect bias osc filter circuit, but to save a lot of poking around I'd be grateful for anybody with practical experience of the unit to offer advice.
Thanks in advance.
solderon29
U.K.West Midlands
Posts 764
Interesting.The bias osc should'nt be active in playback of course.It seems as though there is some problem with system switching?
There are some capacitor issues with the record/play circuit,but this may be due to a faulty record/play reed relay,or it's control.Electrically these little Centre's are proving to be very long lived,considering their complexity.
Worth checking further indeed.
Whereabouts are you sir?
Nick
Søren Hammer
Denmark
Posts 953
The bias osc. is at a very high frequency, 80-100 kHz which is impossible to hear as no generated tones can create harmonics lower than the base frequency.
A more possible answer would be a capacitor fault.
Vinyl records, cassettes, open reel, valve amplifiers and film photography.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Apr 14 2012 10:20 PM
Poor grounding somewhere, tapeheads maybe.
Dish
Posts 2
Dish replied on Sun, Apr 15 2012 12:37 PM
Hi Nick, thanks for the reply, the unit is in Lancs.
Page 1 of 1 (5 items) | RSS
DigiCert Secured Site Seal
