wow the text formatting in that is sure messed up. I spaced the sentences apart when I posted that, not sure why it looks like a run-on sentence ;)
Your video is set as private so I couldn't view it - but the most likely causes are dried lubricants on the tracks (the tray needs to move with very light effort) and you may need to replace the belt as well.
--mika
https
thanks!!
changed vid to public ( it was set to public when I uploaded it....I am not having much luck with browser lately )
the tracks seem lubed, the tray slides very easily until the last 1/4 where it hits that white plastic piece, and there is a lot of resistance to get the tray through that
https://www.youtube.com/watch?v=AxXmxjFlrYE
I wonder if this text formatting will work, I am on a different computer
I'd replace the belt first, it certainly is past its prime anyway.
Jacques
will do, thanks!
does anyone know where the best place to get parts is?
I looked thru the FAQ's and didn't see any links
I am in Ontario, Canada....I also need a belt for the turntable
I can supply correct belts.Email me.
