Beogram 5500 CD tray not closing all the way
ummagumma
Posts 26
ummagumma Posted: Mon, Aug 1 2016 6:38 AM
I have a 5500 and the tray will not close all the way. with about 1/4" to the end, it hits a lot of resistance on that white plastic lubed piece that it needs to flip into Do you think this is due to the rubber belt being old/dry and slipping? or could it be some other adjustment I need to do? I see there are 4 screws that will adjust the height of the tray, but it appears they are as high as they will go I filmed a quick video of it here: https://www.youtube.com/watch?v=AxXmxjFlrYE thanks!
ummagumma
Posts 26
wow the text formatting in that is sure messed up. I spaced the sentences apart when I posted that, not sure why it looks like a run-on sentence ;)
tournedos
Finland
Posts 7,357
Your video is set as private so I couldn't view it - but the most likely causes are dried lubricants on the tracks (the tray needs to move with very light effort) and you may need to replace the belt as well.
--mika
ummagumma
Posts 26
https
thanks!!
changed vid to public ( it was set to public when I uploaded it....I am not having much luck with browser lately )
the tracks seem lubed, the tray slides very easily until the last 1/4 where it hits that white plastic piece, and there is a lot of resistance to get the tray through that
I wonder if this text formatting will work, I am on a different computer
chartz
Burgundy, France
Posts 4,171
chartz replied on Mon, Aug 1 2016 7:06 PM
I'd replace the belt first, it certainly is past its prime anyway.
Jacques
ummagumma
Posts 26
will do, thanks!
does anyone know where the best place to get parts is?
I looked thru the FAQ's and didn't see any links
I am in Ontario, Canada....I also need a belt for the turntable
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Aug 8 2016 10:07 PM
I can supply correct belts.
Email me.
Page 1 of 1 (7 items) | RSS
