Hi
am new to site and am looking for some help.
Does anyone know where you can get woofers reconed/repaired in UK. The woofers in my S80 and cx50 speakers have rotted, or would it be better to replace them and if so what would be a suitable replacement.
thanks
I have used this company - they fixed my M100 woofer very well. They did promise to send me pictures and then didn't but the woofer works fine.
Repairing is better than replacing as you will have problems getting exact replacements. Consider replacing the capacitors in the cross over.
Peter
Thanks Peter will give this company a try.
If your cones are OK, maybe a refoam job will do it, at the same time change the caps in the crossovers. Check here
