Replacement woofers
This post has 3 Replies | 0 Followers
richard1953
Posts 2
richard1953 Posted: Sat, Apr 6 2013 2:31 PM
Hi
am new to site and am looking for some help.
Does anyone know where you can get woofers reconed/repaired in UK.  The woofers in my S80 and cx50 speakers have rotted, or would  it be better to  replace them and if so what would be a suitable  replacement.
thanks
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Apr 6 2013 2:42 PM
I have used this company - they fixed my M100 woofer very well. They did promise to send me pictures and then didn't but the woofer works fine.
Repairing is better than replacing as you will have problems getting exact replacements. Consider replacing the capacitors in the cross over.
Peter
richard1953
Posts 2
Thanks Peter will give this company a try.
Søren Mexico
Mexico City
Posts 6,411
If your cones are OK, maybe a refoam job will do it, at the same time change the caps in the crossovers. Check here
Page 1 of 1 (4 items) | RSS
