Mix Speakers B&O and not B&O
This post has 4 Replies | 0 Followers
SlyParma
Italy
Posts 127
SlyParma Posted: Mon, Apr 28 2014 8:34 AM
Saturday I went to the store to view some projectors. I was excited in front of the Canton Reference 7.2 speakers white.   Beautiful and wonderful sound.
Now I wonder ... how do I connect these speakers, front, instead of BeoLab 8000? Rear I will use the BL4000.
Probably will connect the speakers Canton, to BV7-32, which will connect the projector and bluray.
Michael
Sweden
Posts 2,578
Michael replied on Mon, Apr 28 2014 8:58 AM
The canton speakers are not active, so you can't connect them directly to the beovision. You would need an amplifier in between. The beolink passive might work but it is possibly to weak for them and you would need to hide it somewhere since it is very bulky - as is the canton speakers. They would look strange together with a beovision 7, perhaps less distracting if you have a few meters between the speakers and the tv. The design is completely different.
Millemissen
Flensborg, Denmark
Posts 14,680
As Michael wrote, you will need an amplifier for driving them with the BV.
Theoretically that is no problem - with the right cables/adapters/trigger...
But beware of - how a passive loudspeaker sounds is basically dependent on the amp, which drives it.
Different amps will give you different experiences - from excelent to 'that is not what I heard in the store'.
It can be a tough job to find the right match - the BL Passive as amp surely won't do the job.
This is why B&O for decades has been making speakers with dedicated amps (and DSP's).
If you really like the sound of those speakers, you could make a 'small' setup somewhere else in the house with a matching amp and your main sources.
You should go for BeoLabs in a B&O setup - imo.
Alternatively go for active speakers from another brand.
Second alternative - you could try to get hold on one (or two) of the ICEPower based amps, that can be found (they are rather rare).
Some B&O'ers have made nice setups with them driving the Penta Vox - so why not for a Canton speaker!
SlyParma
Italy
Posts 127
SlyParma replied on Mon, Apr 28 2014 9:34 AM
Which amplifier, high quality, should I put to manage Canton?
And how do I connect it?
I am sure that other users have TV B&O and speakers not B & O. How did you do?
DoubleU
Posts 562
DoubleU replied on Mon, Apr 28 2014 10:57 AM
For these speakers you need a serious 2-way power amplifier. Just 2 line-inputs for left and right, and no volume control. Your BV7 will act as a pre-amplifier. Preferable an amplifier with a trigger input to wake up the amp, and put the the amp in standby. For example the Emotiva XPA-2.
But I would explain your situation at the store where you want to buy these speakers and let them advice or let you test different amps for a good match.
Page 1 of 1 (5 items) | RSS
