Saturday I went to the store to view some projectors. I was excited in front of the Canton Reference 7.2 speakers white. Beautiful and wonderful sound.
Now I wonder ... how do I connect these speakers, front, instead of BeoLab 8000? Rear I will use the BL4000.
Probably will connect the speakers Canton, to BV7-32, which will connect the projector and bluray.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
As Michael wrote, you will need an amplifier for driving them with the BV.
Theoretically that is no problem - with the right cables/adapters/trigger...
But beware of - how a passive loudspeaker sounds is basically dependent on the amp, which drives it.
Different amps will give you different experiences - from excelent to 'that is not what I heard in the store'.
It can be a tough job to find the right match - the BL Passive as amp surely won't do the job.
This is why B&O for decades has been making speakers with dedicated amps (and DSP's).
If you really like the sound of those speakers, you could make a 'small' setup somewhere else in the house with a matching amp and your main sources.
You should go for BeoLabs in a B&O setup - imo.
Alternatively go for active speakers from another brand.
Second alternative - you could try to get hold on one (or two) of the ICEPower based amps, that can be found (they are rather rare).
Some B&O'ers have made nice setups with them driving the Penta Vox - so why not for a Canton speaker!
Which amplifier, high quality, should I put to manage Canton?
And how do I connect it?
I am sure that other users have TV B&O and speakers not B & O. How did you do?
For these speakers you need a serious 2-way power amplifier. Just 2 line-inputs for left and right, and no volume control. Your BV7 will act as a pre-amplifier. Preferable an amplifier with a trigger input to wake up the amp, and put the the amp in standby. For example the Emotiva XPA-2.
But I would explain your situation at the store where you want to buy these speakers and let them advice or let you test different amps for a good match.
