Problems with Beoport
This post has 9 Replies | 1 Follower
sapmi
Switzerland
Posts 32
sapmi Posted: Mon, Apr 28 2014 5:36 PM
Hello it's me again...
First of all, thank you all who answered me for the copies without Beoconnect.
However, I have little problems with Beoport (I really have not any luck, do I? ^_^
When I first download from Bang/olufsen site, I have the Beoport control bar (on the right side of the PC with the four colours as on the Beo4), but when I switch off my computer and restart again later, I have the control bar from Beoplayer. How should I do, so that the Beoport control bar stay?
The second problem is that I have all my music in Beomaster 5 in AAC and it doesn't copy all of my music from there. I know that Beoport goes with Windows Media Player, which has MP3 format but it should support AAC format from Beomaster 5 connected. How should I do to have all my music in it with AAC?
Thank you again for all information added. Best wishes.
elephant
AU
Posts 8,219
elephant replied on Mon, Apr 28 2014 7:31 PM
sapmi:
Sounds like the PC has lost its USB connection to the BeoPort.
Q1a) Did you also power off the BeoPort ?
Q1b) Did you disconnect the BeoPort from the PC ?
sapmi:
Q2a) Can your PC play an AAC file using the Windows Media Player ?
BeoNut since '75
sapmi
Switzerland
Posts 32
sapmi replied on Wed, Apr 30 2014 4:48 PM
I don't think so but how should I do it?
sapmi
Switzerland
Posts 32
sapmi
Switzerland
Posts 32
sapmi replied on Wed, Apr 30 2014 4:58 PM
Oh God, I firstly told you twice, but it is false... I think it is yes, because I have all my music there also, as well as it is on ITunes. Sorry
elephant
AU
Posts 8,219
elephant replied on Wed, Apr 30 2014 9:09 PM
sapmi:
Maybe I need some sleep :) but I found your answer too confusing.
I have edited my post so the questions are numbered and so that you can then number your answers, e.g.:
A1a) xxxx xxx xx x
BeoNut since '75
sapmi
Switzerland
Posts 32
sapmi replied on Wed, Apr 30 2014 10:30 PM
Sorry...
Questions 1 a and b are resolved, thank you...
And for the second question... I have seen that my library was damaged in the Windows Media. What I don't understand is that Beconnect doesn't appear now. I always have Beoconnect in my PC but nothing is happening when I want to open it and my Beomaster 5 is not written under my list of external hard disk...
elephant
AU
Posts 8,219
elephant replied on Fri, May 2 2014 11:52 PM
sapmi:
It seems you have lost a connection somewhere between the Mac and the BM5 - perhaps the BeoPort's player has messed up those connections - I am not a LAN guy so I don't know where to start :(
Also when you say the library has been damaged ... do you mean the files have been corrupted ? or the directories mixed up ? or that you can simply not see it on the LAN ?
BeoNut since '75
sapmi
Switzerland
Posts 32
sapmi replied on Mon, May 5 2014 10:37 PM
I think everything has been resolved. But to be sure, I will erase all my Library in the Windows Media Player because I have many songs double or triple. I will make a copy from Beomaster 5 as well as ITunes...
Then I think the copy in Beoport will be ok as I only choose one (Windows or ITunes)
Do Beoport read AAC files from Windows Media Player? I think so as Beomaster put the songs in it... But sometimes, the covers of the albums are false and I don't know how to change them.
It is simple in ITunes...
sapmi
Switzerland
Posts 32
Page 1 of 1 (10 items) | RSS
