A search on Google revealed the following Danish prices from pricelist may 1:
It seems very flexible for placement. Looking forward to learn more about this new TV soon.
I read it as the (motor) floor stand is included. As well as the remote. But given that the table stand and the floor stand is the same price you can probably choose the table stand at no extra cost.
Raeuber:I wonder if the Floorstand included with the Avant comes without motor.
If you were right, those who do not buy the motor, would have to pull out the speakers manually
Millemissen:If you were right, those who do not buy the motor, would have to pull out the speakers manually MM There is a tv - and there is a BV.
roarmo: BeoVision Avant 55" sølv inkl. Gulvstand, BeoRemote One 9671 65.990,- 4755 Gulvstand med motor 10.995,- 4757 Bordstand med motor 10.995,- 4756 Vægbeslag med motor -højre/venstre drej 10.995,- 4788 Vægbeslag - fixed 4.995,- 1716 BeoRemote One -silver 1.995,- 5007 3D briller 795,- BeoVision Avant 55" sølv inkl. Gulvstand, BeoRemote One 9671 65.990,- 4755 Gulvstand med motor 10.995,- 4757 Bordstand med motor 10.995,- 4756 Vægbeslag med motor -højre/venstre drej 10.995,- 4788 Vægbeslag - fixed 4.995,- 1716 BeoRemote One -silver 1.995,- 5007 3D briller 795,- A search on Google revealed the following Danish prices from pricelist may 1: 1716 BeoRemote One –silver DKK 1.995,-
x:________________________
Just change the 'Go' button to a 'Navi' button and rename 'Display' into 'On' - that's it
Millemissen: Just change the 'Go' button to a 'Navi' button and rename 'Display' into 'On' - that's it
... and either an 'exit' or 'back' button please!
....and the 4 coloured buttons....
Maybe we are just getting back to a Beo4 :)
Jonathan: roarmo: BeoVision Avant 55" sølv inkl. Gulvstand, BeoRemote One Hi Jon I still think that Apple ripped this off for their Apple TV remote 9671 65.990,- 4755 Gulvstand med motor 10.995,- 4757 Bordstand med motor 10.995,- 4756 Vægbeslag med motor -højre/venstre drej 10.995,- 4788 Vægbeslag - fixed 4.995,- 1716 BeoRemote One -silver 1.995,- 5007 3D briller 795,- BeoVision Avant 55" sølv inkl. Gulvstand, BeoRemote One 9671 65.990,- 4755 Gulvstand med motor 10.995,- 4757 Bordstand med motor 10.995,- 4756 Vægbeslag med motor -højre/venstre drej 10.995,- 4788 Vægbeslag - fixed 4.995,- 1716 BeoRemote One -silver 1.995,- 5007 3D briller 795,- A search on Google revealed the following Danish prices from pricelist may 1: 1716 BeoRemote One –silver DKK 1.995,-
Hi Jon
So much so that you can pull out the internals of the Beo1, and replace them with an Apple Remote! It works, an aussie Beoworlder by the name of Dave did it a few years ago!!
I have "seen" it today. Chances are that if you are walking into a B&O store today, someone will be busy setting it up.
Tha panel itself was covered for most of its surface as they were setting up the stand. I could only get a glimpse of the top corners and the back (definitely no need for the Beosystem 4, as discussed in the other thread, and Made in CZ).
The stand. My biggest worry (a single stand for 55,74,84") just materialised. It is BIG. The diameter and the height of the circular base is almost double as the one for the BV11-55 which was meters away in the shop. I might be exaggerating since I haven't seen the complete setup, but it could be a showstopper as far as my requirements are concerned.
Ive heard the stand needs to be big to accomidate the way it swivels so it can turn to you even if your sitting in the corner of a room!
Maybe it will be like a huge Mickey Mouse with round speakers that pop out the sides ?
I just figured out from the price list that it comes with a non-motorised stand (which I am yet to see), so the guy at the dealer basically had no clue when he told me that only motorised stands would be available. Hopefully the standard stand is less prominent!
so it's twice the price of a bv11 ?
glad i got the trade in when i did
no way is this the new avant
the avant was the best sd tv ever made
Does make me wonder..
http://www.whathifi.com/news/netflix-five-years-before-ultra-hd-4k-becomes-mainstream
By which time it will be all change again.
Chris Townsend: Does make me wonder..
Chris, it's a 4K panel, it doesn't mean you're buying it to watch 4K. It's not a necessity. It's an option.
Besides, on a 55" TV, 1080p will be fine. You don't need 4K for a 55". 85", yes, perhaps.
The reason for buying the new Avant shouldn't be 4K. It should be the design and performance foremost, the price second and, last of all, 4K capability.
Theres one type of floor stand and it moves on two axis. The big plate can move 360 degrees and the smaller one, where the tube+tv is mounted, can be adjusted as well. Don't know how much though, but as there's cables connected there is a limit. Can't wait to try it out :)
As for the size, its a heavy and wide tv and theres the laws of gravity - i guess thats why the plate is that big.
/BB
Flappo: so it's twice the price of a bv11 ?
I could be wrong, but I was told it's going to be £7250 in the UK, with a stand and remote. How is that twice the price of a BV11-55 (which is just short of £10K with stand and remote)?
There's so much pre-launch negativity on this board, mostly from people who recently bought a BV. Odd, eh? :)
I worked it out to be £7,700 so somewhere in between would be about right. A very good price point considering whats just gone before!
wish i'd waited now , lol
then again 55 is too big
maybe...
Why the end of the BSys4?
It is still needed and usefull for a pure cinema solution.
BeoGreg:Some of us are worried. B&O tv´s are "less" expensive but you have to change them more often with minimal (if any) trade in value ! Times have changed and will see from tomorrow if it´s for the better. Am I the only one anoyed by the end of danish built ?
a speaker is one thing , a tv or a hifi component
danish built fer me every time
when my bv11 was delivered a tiny piece of paper floated out of the box , it was signed qc tag for the stand
the installers ignored it and threw it away ( but i noticed it )
shame as that's the kind of little thing that companies like leica make a big deal about with their hand built stuff , it adds 'MAGIC'
i think bno are missing a trick here
beobot: Theres one type of floor stand and it moves on two axis. The big plate can move 360 degrees and the smaller one, where the tube+tv is mounted, can be adjusted as well. Don't know how much though, but as there's cables connected there is a limit. Can't wait to try it out :) As for the size, its a heavy and wide tv and theres the laws of gravity - i guess thats why the plate is that big.
Right, it's all about physics! Center of gravity is much higher. It doesn't surprise me, the plate is bigger then the BV11-55 stand.
Sounds odd if the plate can move 360 degrees. But if it can move 180 degrees max, in both directions, there should be no problem with cables.
Fits perfect in the room on the facebook page.
Can be turned both ways - to the table and to the chairs.
vlohjr1:I was initially but having had for a brief time bl8k (dk built) and bl18 (made in cz) I can't tell the difference!
I don't think, there are many differences between "made in DK" and "made in CZ". Czech republic is not in Asia.
Beovision 12 65, Beovision 11 55 Mk II, Beoplay V1 40, Beosound 5 Encore, Beolab 9,beolab 18, Beolab 19, Beoplay A8, Beoplay A9
