Linking CD50 through 5500 System
Professor David A Flynn JP
Belfast, Northern Ireland
Posts 116
Professor David A Flynn JP Posted: Fri, May 16 2014 1:25 PM
Folks - I have just bought a Beogram CD50 to link up with my 5500 series, though it is working well I have to operate it manually as it will not link with the 5500 Top Remote or the 1000 hand remote.  I have linked the two phonos from the rear of the CD player through to a 5 Pin Din linkup.  Is there somewhere that you can get phono connectors that link up with a 7 Pin Din whereby this 5500 will recognise the CD player?
Many thanks David
Professor David A Flynn JP LM
Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
No!
Lee
Newcastle upon Tyne UK
Posts 734
Lee replied on Fri, May 16 2014 1:40 PM
The CD50 has a 7-pin DIN socket on the back. Why not just use the correct 7-pin DIN lead to connect it to your 5500? that will enable datalink and allow you to control it from your MCP.
Lee
Millemissen
Flensborg, Denmark
Posts 14,680
Oh sorry - my mind put on the CD-X.
Lee is right Yes - thumbs up
Cleviebaby
Exeter, United Kingdom
Posts 672
ProfDAFlynn:
David
Oh dear, David, you really have caught it, haven't you!
Cleve
Peter
Earsdon
Posts 11,991
Peter replied on Sat, May 17 2014 8:52 AM
You need a 7 pin DIN lead - it will then work fine. You probably could mess around with an extra cable from the datalink pin on the CD50 to the BM5500 but it will look silly and the DIN cable is simply better.
Peter
chartz
Burgundy, France
Posts 4,171
chartz replied on Sat, May 17 2014 10:05 AM
Since a short lead is only needed really, I bought two DIN 7-pin plugs and I used 20 cm of symetric microphone cable (ground braid and three wires) to make my own. You only have to use PIN 7 if memory serves. A 10 minute job, cost 5€.
Jacques
Posts 116
Thank you all for your posts I have used the correct data cable to link the CD50 through my 5500 series - everything is working fine.
Big Smile
Page 1 of 1 (8 items) | RSS
