Transporting Beogram
This post has 8 Replies | 0 Followers
andytga
Posts 11
andytga Posted: Sun, May 18 2014 10:25 AM
Hi members
i want to transport my Beogram 7002 for repair. A silly question maybe but how
do I secure the tone arm ?
Christian Christensen
Stockholm
Posts 512
Hello andytanga
We discussed this here
http://archivedforum2.beoworld.org/forums/t/7850.aspx
Lots of opinions.
Good Luck
Christian
My re-capped M75 are my precious diamonds.
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, May 18 2014 10:48 AM
Welcome to Beoworld.
Not a silly question at all.  It shows you care about your Beogram.
Do you mean a BG7000 or 8002?
There is a red plastic clip supplied with the BG's from new which slides over the two arms and keeps them stabilised (see picture).  I assume you don't have one?  You can make something out of strips of foam/polystyrene and secure with selotape or something similar.
Are you transporting it yourself or by a courier?  Fasten the transit screws underneath and remove the platter.  If by courier, there are all sorts of other things you can do to help it arrive safely, including removing the lid.  Give us some more info and we can help you more.
Dave
andytga
Posts 11
andytga replied on Sun, May 18 2014 1:10 PM
Sorry Christian it's a beocenter 7002
andytga
Posts 11
andytga replied on Sun, May 18 2014 1:12 PM
Sorry Dave  it's a beocenter 7002 and I will be transporting myself.
Dave Farr
France
Posts 2,283
Dave Farr replied on Sun, May 18 2014 1:42 PM
No problem.
Same basic principles though.  Remove platter, lock transit screws, remove cartridge with the guard down.  Use foam under the arm and secure to the alu plate with tape (surgical adhesive tape is good or any tape that is not too sticky otherwise it will leave a residue of sticky gunk on the aluminium). Painters masking tape should be OK.  Keep the BC as level as possible.
Dave.
Stockholm
Posts 512
Dont forget TLC while transporting.
andytga
Posts 11
andytga replied on Sun, May 18 2014 10:21 PM
Thank you dave
andytga
Posts 11
andytga replied on Sun, May 18 2014 10:23 PM
Thank you Christian
Page 1 of 1 (9 items) | RSS
