The software update - May 2014 - for the BSys4 based tv's
This post has 122 Replies | 6 Followers
Chris
Ostend-BE
Posts 1,170
Chris replied on Mon, May 26 2014 6:32 PM
Indeed the new software for my V1 is arrived: Deezer, DNLA streaming, Standby function for music.... No Netradio
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Amazone
Netherlands
Posts 187
Amazone replied on Mon, May 26 2014 6:59 PM
Nice update. I like the fact that I now can assign speaker groups to sources like spotify. And automatic picture mute on audio sources. No issues with HD.
re Joost
BeoVision 11-55, BeoLab 8000, BeoRemote One BT, AppleTV 4, 2x BeoPlay A2, BeoPlay A1
mawheele
Posts 258
mawheele replied on Mon, May 26 2014 7:56 PM
manitou:
the new software arrived.
and my bv 11 lost contact to the ca-unit -- no hd-tv
deezer and a new picture menu are available, but what should i do without sat-tv in hd.
thank you b+o
Also applied to the new Beovision Avant V1.06. Does B&O publish a change log anywhere?
epkgael
Posts 22
epkgael replied on Mon, May 26 2014 8:10 PM
Ahh, for the BeoSystem4 stand alone as well. Really been waiting for speaker group settings :)
thorne
Posts 315
thorne replied on Mon, May 26 2014 8:13 PM
So what is new in the update?
and how do I know it's been done?
Flappo
Posts 850
Flappo replied on Mon, May 26 2014 8:26 PM
The dlna feature is amazing on my bv11
It works better than my Apple TV did.
Very impressed !
ptbb
Posts 43
ptbb replied on Mon, May 26 2014 8:49 PM
Update is ok, also hd channels work ok, but why there is no net radio? i do not see difference between dlna function before and after update.
Beovision 12 65, Beovision 11 55 Mk II, Beoplay V1 40, Beosound 5 Encore, Beolab 9,beolab 18, Beolab 19, Beoplay A8, Beoplay A9
Millemissen
Flensborg, Denmark
Posts 14,680
@ptbb - if you use the DLNA player function (HomeMedia) as usual, you won't see any difference.
The 'tv' now acts as a 'renderer' - means rhat it plays something that you 'throw at it' from a DLNA control point (could be an iPad app or the WMP).
(At least that is how the Avant reacts. I did not have the chance to test it on my V1 yet - but it should be the same.)
Think Playmaker - the Playmaker is a renderer for audio. You pick what you want to hear and choose where to play it.
Of course the 'tv'-renderer can also play video ---- and the tv turns on from Standby (with the right settings).
Great feature - imo.
P.S. May we hope for the Netradio function in another future update? Would make these BV's perfect!
Simonbeo
Posts 1,451
Simonbeo replied on Mon, May 26 2014 9:12 PM
How exactly do I throw iPad content at my V1 with the new software?
thanks
Beo Century ,Beoplay V1, Beocenter 6, Ex-Beolit 12, Beotime , A8. Beolit 15 , Form 2i , Beolab 2000, Beoplay A3.Beosound 1
Millemissen
Flensborg, Denmark
Posts 14,680
@Simonbeo - do you have a DLNA app on the iPad? Such as PlugPlayer or the 8Player?
N.B. Of cource all devices must be on the same network!
Millemissen
Flensborg, Denmark
Posts 14,680
@Flappo - did not know that - thanksYes - thumbs up
I'll have to try it out as soon as possible.
mr_anders_son
sweden
Posts 1,710
Why not Netradio on Bv11??
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Millemissen
Flensborg, Denmark
Posts 14,680
You could write BeoCare and ask that question!
Some think that they are holding it back - ir order to have something special/exclusive for the Avant
Simonbeo
Posts 1,451
Simonbeo replied on Mon, May 26 2014 9:48 PM
To be a complete Luddite , do you mean they only need to share a router and network address , or is there more to the set-up ?
excuse my ignorance!
Millemissen
Flensborg, Denmark
Posts 14,680
All devices (the BV11/V1..., the device with DLNA control point function, the DLNA server) must be on one/the same network.
The UPnP/DLNA function makes it possible for the devices to see each other.
This was needed for being able to use the HomeMedia function of the BV11/V1....
Now you can use a tablet/iPad/iPhone/SmartPhone... with a DLNA software on it, to 'command your BV11/V1...' to play the files from a server on your network.
If you - like me - have several hundrets of music albums, you may find it very hard to navigate in the HomeMedia section on the BV, and much easier to search for/find, what you want to play in a good app-interface (say on an iPad).
Millemissen
Flensborg, Denmark
Posts 14,680
thorne:
2: go to 'Service' in the menu and look for latest sw-version.
Do a search for new sw, or just wait untill tomorrow (if you have the automatic sw-update activated).
1: what's in the update is briefly explained on the screen, when the new sw is found.
Simonbeo
Posts 1,451
Simonbeo replied on Tue, May 27 2014 6:57 AM
Is there a new start-up screen again ?
we will see later...
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Tue, May 27 2014 7:41 AM
My BV11 did not auto update as it should have done, so I did a manual check and update (from the internet) this morning.
After updating I found that my HDMI 1 source (Cambridge DVD) remained in the source menu, but HDMI 2 (Apple TV) had gone. After going to 'edit' HDMI 2 could be selected and I had to go through all the set-up options again for the Apple TV. Interestingly, this time pictures came up of the connections to be made to the TV (even though they had all already been made).
On completion, the menu now has an item it has called 'Apple Remote' and HDMI 2 does not actually appear.
Graham
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, May 27 2014 7:47 AM
mr_anders_son:
I'm disappointed, was really looking forward for Netradio. And why a Deezer PLUS account? Anyway the stand-byscreen function is very useful as is the saving of a speaker-group. Looks the TV is ready for a Beoremote One also.
-Countdown to the next update (Netradio)!-
vikinger
Posts 5,422
vikinger replied on Tue, May 27 2014 8:06 AM
Chris:
mr_anders_son:
Never say never, but when I found that I could not stream internet radio via the BV11 web browser my dealer sent a query to Struer. The answer came back that the best thing to do was attach another B&O source with Netradio, and that the TV itself would not do it. There was no mention of a future TV upgrade for Netradio.
The Apple TV is a fairly good way to get Netradio.... I say fairly because Apple have their own categorisation of stations in their menu and finding a particular station is not straight forward. There doesn't seem to be a way of selecting the stream download quality, and you have to put up with Apple's own pictures rather than view the slide show that the station may have put out to accompany the broadcast.
Graham
jans
Belgium
Posts 394
jans replied on Tue, May 27 2014 8:10 AM
Hey MM
Couple of questions:
How does the new DLNA function work? This is not clear to me. Isn't it the same as HomeMedia?
Which DLNA app would you need on your iPad? Do you need specific software on your NAS?
How do I configure the screen 'stand by' function for audio sources?
Greetz
Jan
Millemissen
Flensborg, Denmark
Posts 14,680
vikinger:
Graham
When you have seen how Netradio works on the Avant, you would surely choose that over the netradio from the ATV.
You can pick the stations and assign them to a digit on the remote - and skip to next.....
If you assign the Netradio to 'Radio' on the Beo4, you can use Netradio just like we are used to with the old analog radio.
And the interface on the tv is different - exactly as we expect from B&O.
Untill the arrival (?) of Netradio on the BV11/V1 I'll keep on AirPlaying radio from the TuneIn iPad app!
Millemissen
Flensborg, Denmark
Posts 14,680
jans:
you don't - so it seems - it's 'auto'.
At least I haven't found a setting for that - which is quite odd!
Hope they change that in an update - to let us decide for On or Off.
Better would be, if they would make it source dependent and also let us decide for how long it takes 'till the screen mutes.
Millemissen
Flensborg, Denmark
Posts 14,680
jans:
Hey MM
Sure it is HomeMedia - but now you can 'feed' the BV from a DLNA app. I mostly use the 8Player or the PlugPlayer (iOS).
Search for DLNA app's on iOS or Android (whatever you use), or (if you are Windows-user) try the 'Play To' function in WMP.
On your NAS you need a DLNA server - but if you have used the HomeMedia of your tv, you will already have one.
Note: the DLNA app can also work as server - means you can use the music, video (dependent on the file format) stored on the device for streaming to the BV.
Here is an example - you can see that my V1 as well as my Playmaker (and the iPad itself) is recognized as a renderer on my network.
You see the three servers that (at the moment) are available on my network - and the main folders/categories of the Synology DLNA server:
Emil Jensen
Denmark
Posts 766
Any news about the USB REC funktion?
Millemissen
Flensborg, Denmark
Posts 14,680
When you pick a video/movie in the interface of the 8Player, you get a screen like this - and the movie is playing on the BV.
You can (with the right settings) start from Standby - no need for pushing the HomeMedia 'button' first, and you can 'pause' with the Beo4 as usual:
Millemissen
Flensborg, Denmark
Posts 14,680
And here is music playing - you can 'pause/play' and skip tracks as usual.
The cover and the info's are shown as usual on the BV.
Note: now the screen auto-mutes after some seconds.
Millemissen
Flensborg, Denmark
Posts 14,680
emilos:
Not that I know - did not expect that to come for the BV11/V1 now.
Again - we may hope (at least I do).
But it might be that the 'engine se-version' of the BV11 and/or theV1 can't handle that.
Emil Jensen
Denmark
Posts 766
Nice with the pics MM. That looks like a funktion there is useful.
Yes USB Rec could be the thing that could make me pull the trigger on a V1 or beosystem 4.
Millemissen
Flensborg, Denmark
Posts 14,680
emilos:
...especially for music - if you have a lot of it on a local drive.
Plays 24/96 files fine - by the way!
Raeuber
Germany
Posts 2,542
Raeuber replied on Tue, May 27 2014 6:36 PM
Millemissen:
Hi MM,
how you can bring back the sreen after auto-mute? With P.MUTE or source key? And after bring back the screen, does the screen auto-mute again?
Greets
Räuber
vikinger
Posts 5,422
vikinger replied on Tue, May 27 2014 7:12 PM
Another point of detail. On switching on the BV11 the name 'Bang & Olufsen' no longer appears bottom right before the curtains open.
It is now a rather larger name/ logo at the centre  of the screen with a waving / dimming sort of image.
Graham
schatzoy
Zurich
Posts 66
schatzoy replied on Tue, May 27 2014 8:20 PM
I have updated my BV 11-55 and experience problems with HbbTV. When the display shows up, the screen goes black for half a second, every time I switch to a channel with HbbTV. When switching to another channel, the HbbTV from the previous channel is shown except from the new channel. When switching channels, for a brief moment the message "no tuner available" is displayed. Annoying and clearly a bug.
jans
Belgium
Posts 394
jans replied on Tue, May 27 2014 9:35 PM
Hello Millemissen,
I installed 8player on my iPad and it works very nicely.
However, I can't make music play directly on my V1. It seems that I first have to start a movie and then switch to music. Any thoughts what's wrong?
Is the screenshot you added for music from 8player? Mine looks totally different. By the way, nice to see that you also like Agnes Obel! She is soooo good!
All in all, DLNA is a very nice feature added to the V1. This is what I like about it so much. With Spotify, Deezer, YouTube and now this DLNa functionality, the functionality becomes better and better. I am really looking forward for NetRadio to make things complete.
Anyhow, this is the way to go for B&O!
Regards,
Jan
lundmark
Stockholm, Sweden
Posts 105
lundmark replied on Tue, May 27 2014 9:46 PM
  • So the new DLNA media slinging feature is an AirPlay knock-off? I haven't been able to try it yet. Sounds alright, but I've already got an Apple TV.
  • I am extremely happy about being able to configure individual speaker groups for individual sources. I've set my audio-only sources to only use my external speakers. A small feature, but a huge convenience.
  • Not sure about Deezer. Why would anyone use that instead of Spotify?
  • There's a new monitor picture mode. How does it differ from the game mode?
  • The menu system has a new highlight design.
  • Have you noticed anything else that's different?
Millemissen
Flensborg, Denmark
Posts 14,680
Raeuber:
Hi MM,
Hi Räuber,
The only way I - so far - have found out, is to to move/press the navi-button.
This also brings back the overview of the servers and the last played items.
To 'get rid of' that list you then have to press 'back'.
Alternatively you push the 'blue button' - this brings on the 'info' about the file.
Pushing that again take the 'info' away and leaves the cover with trackname.... on the screen
Then the 'fun' goes on - after some time the screen mutes again.
N.B. For how long the screen stayes on, I haven't quite figured out - some times it seems longer than other times ???
Edit! While writing this the scren hasn't muted for more than three/four tracks - more than 15 minutes with the screen on Unsure
Edit! Edit! The screen is stiiiil on - don't know if it was the 'blue-blue button push' that made it?
I must say - it is rather uncomfortable. Maybe I missed something Crying
And maybe - after all - the 'old' 'P-Mute' function was better?
Problem is - you can't turn off the 'Auto P-Mute'.
I would very much like to hear how things are with other BV11/12NG/V1-users.
Guess I'll have to 'play around' a bit more tomorrow.
Please note - I have only tried this in the 'HomeMedia' function.
But I can't imagine, that it should be different with Spotify.
P.S. Sorry for the long 'not-answer'!
Simonbeo
Posts 1,451
Simonbeo replied on Tue, May 27 2014 10:49 PM
Only a minor achievement , but I updated the software and threw images by DNLA from iPad !
very exciting with that App you recommended Millemissen . But no Spotify from iPad?
thanks for the tips
Millemissen
Flensborg, Denmark
Posts 14,680
jans:
Hello Millemissen,
1: my V1 turns on from scratch, when I start playing a track in the 8Player.
Sure you have 'quicktimers' activated?
2: you can costumize the main screen of the 8Player - under settings.
3: DLNA is not new - it's the renderer function that is new.
Millemissen
Flensborg, Denmark
Posts 14,680
lundmark:
Definitely not!
But usefull - especially if you don't have (or want) a ATV/iDevice combo.
I love my ATV/iPad Stick out tongue
Page 2 of 4 (123 items) < Previous 1 2 3 4 Next > | RSS
