H6 Replacement Audio Cable?
This post has 48 Replies | 2 Followers
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Mon, May 19 2014 11:12 PM
Does anyone have a suggestion for replacement audio cable for the H6 as the one that that is supplied with the headphones is 1) to short when used at home and 2) has a remote which I'll never use. Something like this; but which saddly doesn't look to fit the socket on the headphones:
  • Filed under:
Millemissen
Flensborg, Denmark
Posts 14,680
The supplied cable would be the reason why I do not want to buy this otherwise excelent headphone.
Dave Farr
France
Posts 2,283
Dave Farr replied on Tue, May 20 2014 7:24 AM
For any B&O cable I always ask Steve at 'Sounds Heavenly' - bottom of the Beoworld pages.  If you tell him what you want, he can normally  make it for you or will have something already in stock.
Dave.
js
Posts 382
js replied on Tue, May 20 2014 8:28 AM
I requested this already from Steve at 'Sounds Heavenly' some time ago, but he did not have a solution. He said maybe in the course of the year. Maybe good to ask again.
symmes
Posts 247
symmes replied on Tue, May 20 2014 8:44 PM
Millemissen:
That's a joke, right?
js
Posts 382
js replied on Tue, May 20 2014 9:05 PM
symmes:
Well, no. The 4-pin connector of the supplied cable does not work correctly with most headphone amps which typically have a 3-pin socket, and the socket of the headphone itself is too small to connect a standard aftermarket 3-pin cable instead.
So the H6 is fine with an iDevice, but does not work with most high quality headphone amps. So it is pretty useless for non-mobile applications.
I fail to understand why B&O does not provide a choice of 4-pin (with mic/remote for mobile applications) and 3-pin (for hi-fi applications) cables in the box, like e.g. B&W does with the P5.
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, May 21 2014 4:43 AM
There are adapters to convert from 4 to 3 conductor plugs. I've got one that goes from the 4 conductor mini plug to a standard 3 conductor 1/4 inch headphone plug. Or just make one yourself.
Jeff
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Wed, May 21 2014 9:39 AM
Jeff:
That is a bad workaround as I'm looking for a clean cable without the remote mumbo jumbo... So not what I'm looking for.
symmes
Posts 247
symmes replied on Wed, May 21 2014 12:11 PM
js:
symmes:
But it's a BeoPlay, therefore it is designed for that end user. For a more sophisticated listener who uses a headphone amp but might like the H6, like yourself, there is an aftermarket.  Isn't it nice that the BeoPlay cable is a quick connect/disconnect?
js
Posts 382
js replied on Wed, May 21 2014 1:17 PM
symmes:
The H6 is a very good headphone. It shines with a good source more than it will ever do with an iDevice. It may be marketed for mobile applications, but it is designed to do more/better than that.
symmes:
Of course it is. The problem is that the socket on the headphone is too small for an aftermarket cable.
symmes
Posts 247
symmes replied on Wed, May 21 2014 4:05 PM
Is this what you are looking for? Hope it works.
Cheap. Might need to pay more for high altitude, assembled by elves, or blessed by Pope version. ;-)
http://www.amazon.com/Hosa-CMP159-Stereo-Breakout-10-Feet/dp/B005HGM1D6/ref=sr_1_1?s=musical-instruments&ie=UTF8&qid=1400684178&sr=1-1
Jeff
USA
Posts 3,793
Silver Member
Jeff replied on Wed, May 21 2014 4:13 PM
kimhav:
Jeff:
If you're that picky, I'm betting you go thru life disappointed and irritated a lot.
Jeff
1983beo
Posts 127
1983beo replied on Thu, May 22 2014 2:58 PM
You can order a extensions cable 4 pole to 3 pole at youre local dealer. It s a bang & OLufsen sparepart.
Millemissen
Flensborg, Denmark
Posts 14,680
@1983beo - could you explain that a bit?
Does it mean the you can extend the existing cable in order to make it longer - or does it mean that you could use it instead?
1983beo
Posts 127
1983beo replied on Tue, May 27 2014 11:13 AM
It is a extension cord in 2 meters with a female 4 plug and a male 3 ring plug
I think an extension cord is fine. The normal cord is to short to listen to the sound of the tv.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Oct 27 2014 8:31 PM
Well, just for the fun of it I did do some searches at eBay and found one seller now from China who has a nice replacement cable for the H6 in various lenght (1.2m to 3.0m) and... wait for it... no microphone/remote on the cable.
Direct link to this item.
Millemissen
Flensborg, Denmark
Posts 14,680
Interesting - please let us know if it is good.
I bought an extension cable for mine, but this would be a better solution.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Oct 27 2014 8:55 PM
Just ordered 1.8 meters cable and it most likely will take something like 8-20 days before it arrives from Hong Kong. But, I'll keep you posted. But, I do think that this replacement cable will do the trick and the seller do also sell replacemnt for Sennheiser and AKG headphones and so far no negative feedback.
Roger
Norway
Posts 417
Roger replied on Tue, Oct 28 2014 9:34 AM
Interested reading, indeed. Do any of you know if this will be an issue with the new headphones as well, the H2?
Roger
BeoGreg
South of France
Posts 1,417
BeoGreg replied on Tue, Oct 28 2014 1:39 PM
Don't know about the H2, but the sheep told me the H8 will be wireless so no cable issue Big Smile
Millemissen
Flensborg, Denmark
Posts 14,680
Boy, you guys are teasing Cool
But you might be right - Tue mentioned to me at the General Meeting in Struer this year, that more headphones were in the pipeline.
N.B. Don't ask for details ---- (of course) he did not tell more about them.
Mark
London
Posts 1,063
Mark replied on Tue, Oct 28 2014 2:54 PM
BeoGreg:
makes sense as they've given the nod to Bluetooth technology, any ideas when wireless cans might be released ?
Mark
London
Posts 1,063
Mark replied on Tue, Oct 28 2014 3:02 PM
just been doing some research and there seems to be a campaign brewing....
Millemissen
Flensborg, Denmark
Posts 14,680
Let's have a pic of the backside as well, please Big Smile
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Thu, Nov 6 2014 6:13 PM
Millemissen:
Interesting - please let us know if it is good. I bought an extension cable for mine, but this would be a better solution. MM
Got the cable today and it looks quite nice and was very well packaged. But, when trying out a few tracks with high pitch and high frequencies I get the impression that the cable do have negative impact on the audio. Might be placebo effect so need to try a bit more and have some one else to change the cable without me seeing it. But, the treble seems to be slighly cut off. Tracks which have an almost painfull hight frequency intros now sounds a bit flat.
Roger
Norway
Posts 417
Roger replied on Fri, Nov 7 2014 7:05 AM
Thanks for sharing. I'll keep on waiting until you can rule out the placebo effect before I place an order. I do prefer the H6 over the H2 and H8, and the Bluetooth-option is of little relevance to the BV10 I'll be using the headphones with - but I do need an extention cable...
Roger
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Fri, Nov 7 2014 10:28 AM
Did some additional testing and one track where it's really clear that this cable isn't up for the jobb is when playing Dancehall Queen from Robyn's Body Talk album. The intro has a quite high pitch sound which is cut of and sounds flat. So guess that they've been using really low quality wire for the cable.
I've send the seller some feedback and questions regarding the cable; so let's see what they come back with. Then again, it's a cable for £10, so I'm not going to put that much efforts into this. Let's they might try to improve the quality of the cable and happy to pay additional few pounds for that.
If anyone of you guys are located in the Cph/Mlm region; let me know if you want to test the cable to get some additional ears to try it out.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Fri, Jan 16 2015 10:49 AM
Dear Community Friends,
I've today received an email from B&O customers services that there is now a replacement cable available for the H6;
"Dear Mr Haverblad,
I am happy to inform you that we can now offer an audio cable for your BeoPlay H6. The cable is available in two lengths, 0.5 m and 2.5 m.
Please contact your Bang & Olufsen retailer for further information about delivery time and prices
Have a great weekend.
Kind regards,
Customer Service"
Millemissen
Flensborg, Denmark
Posts 14,680
Thank you very much for that info.
I guess a lot of H6-users will be happy with that.
Dave Farr
France
Posts 2,283
Dave Farr replied on Fri, Jan 16 2015 11:27 AM
Many thanks for the update.  I'm sure they won't be 10 GBP but the quality should be as B&O intended.  2.5 metre length is just about right for TV watching for those that can still connect their headphones to the TV!
Reading the post from Steve at Sounds Heavenly, it beggars belief that B&O have removed this facility from new TV's in the range.
Dave.
leosgonewild
Helsinki, Finland
Posts 2,373
I paid 35€ for the original length replacement cable....
elephant
AU
Posts 8,219
elephant replied on Mon, Feb 16 2015 12:17 AM
I paid AU$44 for a "long cable" which turned out to be (a) black and (b) minus any controls and (c) does not propogate the existing signals through.
All of which is a disappointment.
It was in a nice little BeoPlay package - and its texture is much nicer than the average cable one buys from electronics stores.
Did I end up with a generic B&O extension cable instead of a specialised H6 extension ?
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
I use my H6 mainly, when I am listening to music from the headphone-output of my BeoMaster.
They are too heavy and too big for on-the-go.
For this the H2's are perfect.
The 2,5 meter cable is just right for in-house-listening.
Note: No need to ask your dealer - you can not get this cable in other colours!
This is the cable, that they should have supplied with the H6 (with different colour options).
The one with the remote should have been the optional choice - IMO.....buy that, if you need it!
Millemissen
Flensborg, Denmark
Posts 14,680
Just realized that I gave my picture a wrong filename.
It is not an 'extension cable'!
The correct name would be 'replacement cable''.
Or simply 'H6 headphone cable'.
Anyway - you can see that by looking at it Smile
elephant
AU
Posts 8,219
elephant replied on Mon, Feb 16 2015 9:15 PM
Yes. The picture matches my cable and its packaging.
I still think it is designed for being inside a cupboard (eg MacMini to BeoPort) than on display with the lovely aesthetic of the H6
BeoNut since '75
Millemissen
Flensborg, Denmark
Posts 14,680
It is definitely designed for the H6.
The problem with other similar cables was, that they don't fit in to the headphone.
The plugs are smaller.
What pi**es me off is, that I have to use a dark cable with my natural leather H6.
For the price they charge, they should offer more colour-options.
MSuper AngryM
elephant
AU
Posts 8,219
elephant replied on Mon, Feb 16 2015 10:49 PM
Equally peeved. And I agree.
BeoNut since '75
js
Posts 382
js replied on Wed, Feb 18 2015 1:10 PM
Millemissen:
Millemissen:
Hi MM,
I tried to order the H6 replacement cable (2.5 meter without remote) from my dealer, but he was confused and unable to identify this cable in his product list.
He suggested product ref. 1973722 but he was not sure at all.
Could you please verify the correct product reference on your own packaging and confirm? That would be much appreciated.
Many thanks  Smile
js
Posts 382
js replied on Wed, Feb 18 2015 1:16 PM
elephant:
a "long cable" which turned out to [...] does not propogate the existing signals through.
Hi elephant, do you have the same one as MM? In this case, before I order one myself, could you please confirm what you mean: is this cable degrading the signal and the audio quality? Which sort of degradation are you hearing? Many thanks for the clarification.
By the way: MM, do you hear a signal degradation as well? Thanks to you too for you rfeedback. Smile
Roger
Norway
Posts 417
Roger replied on Wed, Feb 18 2015 1:20 PM
The 2.5 meter cable without remote control has product number 1973722 and has type no 9737.
Roger
Page 1 of 2 (49 items) 1 2 Next > | RSS
