Update NL/ML converter
This post has 5 Replies | 2 Followers
Chris
Ostend-BE
Posts 1,170
Chris Posted: Tue, May 27 2014 10:37 AM
There is a new software update also on the NL/ML converter. Added TV ON, Music ON in the IR mapping. Have to find out the advantages...
Current Version : 1.3.0.0
Release Notes:
  • Removed H8 telegram logging to /tmp.
  • Removed thrift client connection and disconnection notifications.
Edit : Spotify did not allow this, but Deezer can be used in your link arrangement.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Nebelfelsen
Posts 27
Thanks for the Information.
How can I update the converter? When I try to access the configuration Panel via my Internet browser I am asked for username and password...
Nebelfelsen
Posts 27
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, May 27 2014 3:54 PM
Try : admin
If it does not work you have to reset the converter
Millemissen
Flensborg, Denmark
Posts 14,680
Maybe it already is updated - if set to 'automatic update'.
Nebelfelsen
Posts 27
Thanks, it has updated automatically.
admin / admin works as login by the way
Page 1 of 1 (6 items) | RSS
