There is a new software update also on the NL/ML converter. Added TV ON, Music ON in the IR mapping. Have to find out the advantages...
Current Version : 1.3.0.0
Release Notes:
Edit : Spotify did not allow this, but Deezer can be used in your link arrangement.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Thanks for the Information.
How can I update the converter? When I try to access the configuration Panel via my Internet browser I am asked for username and password...
Try : admin
If it does not work you have to reset the converter
Maybe it already is updated - if set to 'automatic update'.
Thanks, it has updated automatically.
admin / admin works as login by the way
