I'm using a Samsung screen. One nice feature is that you can disable the start-up Samsung logo. However, there is a brief resolution notification that you can't turn off. It's these little details that are good to keep in mind to keep a clean electronic curtain effect.
And it is reminding you that you don't use a B&O display
By the way - do you know which (other) displays are supported?
Supposedly with a system4 practically anything will be supported, or Henrik will capture the code if you send the remote, I'm told.
I have wrestled and wrangled with this for several weeks but it seems like the projector will give me a much better image and I can create some drama with curtains, shades, etc. I'm going projector for my project. . .wish me luck!
Means: you would not recommend using a non-B&O display/tv (with the BSys4)???
