Anyone using a 3rd party panel?
mjmedlo
Posts 922
mjmedlo Posted: Wed, Jun 4 2014 10:29 PM
I am adding a Beosystem 4 to the mix, replacing bv4-65 and sys3. Would like to add an 85 inch or larger panel.
I've considered a projector but it's in a basement and I'm worried about getting through walls, etc.
Anyone using a 3d party panel with system that could make a recommendation?
beojeff
USA
Posts 2,012
beojeff replied on Thu, Jun 5 2014 2:38 PM
I'm using a Samsung screen. One nice feature is that you can disable the start-up Samsung logo. However, there is a brief resolution notification that you can't turn off. It's these little details that are good to keep in mind to keep a clean electronic curtain effect.
Millemissen
Flensborg, Denmark
Posts 14,680
And it is reminding you that you don't use a B&O display Big Smile
By the way - do you know which (other) displays are supported?
mjmedlo
Posts 922
mjmedlo replied on Thu, Jun 5 2014 4:41 PM
Supposedly with a system4 practically anything will be supported, or Henrik will  capture the code if you send the remote, I'm told.
I have wrestled and wrangled with this for several weeks but it seems like the projector will give me a much better image and I can create some drama with curtains, shades, etc.  I'm going projector for my project. . .wish me luck!
Millemissen
Flensborg, Denmark
Posts 14,680
Means: you would not recommend using a non-B&O display/tv (with the BSys4)???
spezializten
Posts 67
Bear in mind when choosing a 3rd party screen with BS3 you can only have 60hz output. I think this isn't the case with BS4 but can anyone confirm it?
Page 1 of 1 (6 items) | RSS
