Essence remote and playmaker
This post has 31 Replies | 4 Followers
badgersurf
Posts 539
badgersurf Posted: Wed, Jun 25 2014 10:45 AM
I know the remote for the BS essence can be paired with a playmaker (as mentioned in previous threads), but what can it actually do / control?
Toby
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Wed, Jun 25 2014 2:30 PM
How the BeoSound Essence Remote control can be paired with Playmaker ? Confused
badgersurf
Posts 539
It has been talked about before but not in any detail.
Also it mentions it on the B&O FAQ
http://bogo.custhelp.com/app/answers/detail/a_id/10014/~/can-i-use-beosound-essence-remote-with-another-bang-%26-olufsen-product%3F
Millemissen
Flensborg, Denmark
Posts 14,680
Good question - I have tried to get an answer to that for some time now.
No one (no dealer) seems to have been informed about this - and the possibilities included.
The only information avaible is the link above.
Very mysterious Huh?
P.S. A direct 'pairing' with the Playmaker will not be possible - but some kind of ir-control might be.
PhilLondon
London
Posts 3,637
Looking at the document, you'll have to set it in Beo4 IR (radio) mode.
Beoworld app with direct photo upload and emoticons.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Wed, Jun 25 2014 9:49 PM
Millemissen:
....A direct 'pairing' with the Playmaker will not be possible - but some kind of ir-control might be.
I am agree.
What a shame that Bang & Olufsen can not inform dealers about possibilities ! Sad
badgersurf
Posts 539
badgersurf replied on Wed, Jun 25 2014 10:18 PM
The document also has a light mode for home automation, wish that B&O would publish more info on the possibilities.
Millemissen
Flensborg, Denmark
Posts 14,680
PhilLondon:
Which effect would a 'Radio ir-code' send to a Playmaker have Confused
PhilLondon
London
Posts 3,637
PhilLondon replied on Wed, Jun 25 2014 10:33 PM
Millemissen:
"Beo 4 Radio IR Code" are the codes sent by a Beo4 when controlling an Audio product.
The Playmaker works with the Beo4.
Millemissen
Flensborg, Denmark
Posts 14,680
And what will happen (to/with the Playmaker), if 'you' push the button on the wheel - after putting the remote into 'mode 2/Radio ir-code'?
And what is the difference to 'ir-mode 4'?
I am very eager to learn more about this.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Wed, Jun 25 2014 11:03 PM
Which are concretely these codes ? Cool
KMA
Posts 621
KMA replied on Wed, Jun 25 2014 11:18 PM
Millemissen:
Me too.
I dismissed my intent to buy the Essence in the Spring — I saw it as a too limited product, and didn't see the benefit over Playmaker.
The FAQ info is very interesting: being able to have more uses for the Essence's remote, and on the other hand being able to use Beo4 (Beo5 / BR1) to control the Essence's main unit.
I'd like to know more of the use-scenarios.
KMA
B&O product history since 1991: Ridiculously long to list in a signature.
BillC
Posts 121
BillC replied on Wed, Jun 25 2014 11:26 PM
Hi there
I have the playmaker and Essence remote. My Essence remote has been set to IR mode (not the BeoPlay one) and it drives the Playmaker.
I mainly use the Essence to drive the volume and haven't bothered to workout what the buttons do. BTW I never knew what were the Beo4 button mapping for Playmaker were.
FYI my system is rather strange, the Playmaker is used as the link between my Beolab 3s and my HTPC ie
HTPC -->Playmaker--->Beolab3
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Thu, Jun 26 2014 3:36 AM
Thanks BillC for your information. Yes - thumbs up
Millemissen
Flensborg, Denmark
Posts 14,680
Thank - but not much more than a rather expensive volume-controller in your case.
There must be more to it!
And the 'ir-input port' on the box is still a mystery too Huh?
badgersurf
Posts 539
badgersurf replied on Thu, Jun 26 2014 11:18 AM
Having read all the FAQ I could find on the essence and the playmaker as well as the manuals, I guess the essence remote when combined with a playmaker will just do the play (i.e turn on), standby  and volume, there is no previous or next track option.
Millemissen
Flensborg, Denmark
Posts 14,680
You can't 'turn on' a Playmaker.
You have to use a command on the Beo4 (A.Mem = AirPlay and A.Aux = Line In) or just 'throw' something (AirPlay, DLNA or sound from a line-in connected source) at it.
Mr 10Percent
So West, Its Now East
Posts 591
Playmaker, Essence etc...All useless until B&O develop a cross platform media player that can control everything from the interface to the streaming to the media control to the final reciever.
Digital revolution is great. It just does not all work as one integrated system but a string of many systems - some of whcih are not fully compatable with one another or have a habit of dropping out or crashing on one another.
Millemissen
Flensborg, Denmark
Posts 14,680
It may be your '10cents' - my Playmaker nevertheless is far from being useless!
But overall, you are right - we are still waiting for that solution from B&O.
Mr 10Percent
Posts 591
Nothing wrong with the B&O hardware. It is the software that "glues" all these standards/affiliations together.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Thu, Jun 26 2014 9:13 PM
@Mr10Percent
BeoProducts are usually good but softwares are not perfect.
Bang & Olufsen need absolutely to invest in engineer staff. Stick out tongue
Millemissen
Flensborg, Denmark
Posts 14,680
Maybe that is why they are 'getting' more money now?
elephant
AU
Posts 8,219
elephant replied on Thu, Jun 26 2014 10:44 PM
badgersurf:
My reading of the sparse essence manuals says the it plays the last source (e.g. Airplaying iDevice) unless it is "unavailable" in which case it defaults to internet radio.
And that the left hand side of the ring ("<") skips back one unit in the playlist (station or track) or a right hand side (">") click will skip forwards within the playing playlist (e.g. list of internet radio stations)
BeoNut since '75
moxxey
South West, UK
Posts 5,359
moxxey replied on Thu, Jun 26 2014 11:01 PM
I have a PM and the Essence remote. It does very little. Will report back tomorrow...,after I sleep off a bottle of champagne this evening :)
But, I'd recommend against it. Easier to control the PM using your computer or iPhone.
BillC
Posts 121
BillC replied on Thu, Jun 26 2014 11:17 PM
Yep, actually that's the only reason why I bought it Big Smile - I wanted an analog style dial wheel to change volume. Yes I could already do the volume change with the Beo4 remote or iPad but I prefer a dial - sorry I'm a bit old fashion with that.
Millemissen:
moxxey
South West, UK
Posts 5,359
moxxey replied on Fri, Jun 27 2014 9:46 AM
Well, I'm back and my feedback is, it's an expensive volume control and fairly pointless, really.
I have a BeoCentre 2 connected to the PM, which both feed the BL18s. I can play a CD via the BC2 or stream audio to the PM.
The Essence remote will control the volume, but won't control the BC2 if it's set to IR 4 mode. Which means you either have to get up and change tracks manually or use a Beo4. You can set it to IR 2 mode, but then that won't control the PM.
It won't control my forthcoming A9 either, apart from volume.
BeoBoy68
Alsace 🇨🇵
Posts 1,247
BeoBoy68 replied on Fri, Jun 27 2014 11:42 AM
Effectively
This remote control has been studied for the BeoSound Essence.
Functions are very limited with other BeoProducts. Sad
Millemissen
Flensborg, Denmark
Posts 14,680
Why then the different ir-modes - some of those 'for future use'??
badgersurf
Posts 539
Thanks for confirming that the essence remote with a playmaker is just a volume control. Was thinking of maybe using it in the bathroom but cannot see the point if I can set the volume with my ipad before having a bath.
Hopefully B&O will at some point in the near future bring out an update and have one app that will work with the playmaker, essence and NL TV’s, but maybe that is a wish too far!
tradingman
Posts 41
How does the remote communicates with the PM? I could not find an IR-Port on the remote Confused
Regards
Millemissen
Flensborg, Denmark
Posts 14,680
tradingman:
Please check the B&O FAQ or see link, that badgersurf provided on the first page.
There is no 'ir-port' on the remote - unless you call an 'ir-sender' a port.
tradingman
Posts 41
Of course - IR-Sender Big Smile
Page 1 of 1 (32 items) | RSS
