I thought I had maybe a failing cartridge as the right channel seemed weak. I moved it to another amp and then it sounded ok for a few records.
Then after a record was done playing and it parked the tone arm it started making static sounds through the speakers as if someone was rubbing the needle. I unplugged it and plugged it back it and its fine again. Parks fine etc.
Seems intermittent any ideas?
If you are using a correct dual-shield cable, you could have a bad muting relay.
I think you are correct. Someone else mentioned bad muting relay. Well its 1/2 bad. It normally works fine, but must be on its last leg or something.
Yes proper hook ups. Just started doing it today.
