Beogram 8002 new symptom
RAJOD
Posts 159
Silver Member
RAJOD Posted: Thu, Jul 3 2014 11:54 PM
I thought I had maybe a failing cartridge as the right channel seemed weak.  I moved it to another amp and then it sounded ok for a few records.
Then after a record was done playing and it parked the tone arm it started making static sounds through the speakers as if someone was rubbing the needle.   I unplugged it and plugged it back it and its fine again.  Parks fine etc.
Seems intermittent any ideas?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jul 4 2014 7:09 AM
If you are using a correct dual-shield cable, you could have a bad muting relay.
RAJOD
Posts 159
Silver Member
RAJOD replied on Fri, Jul 4 2014 7:13 AM
I think you are correct.  Someone else mentioned bad muting relay.  Well its 1/2 bad.  It normally works fine,  but must be on its last leg or something.
Yes proper hook ups.  Just started doing it today.
Page 1 of 1 (3 items) | RSS
