Hi all can anyone tell me if its possible to connect a passive subwoofer to my 1980 Beocenter 7000 using the speaker outputs. Cheers Phil
Yes it is possible.
The way to make the passive sub (e.g. Beovox Cona) work with your BC7000 will be to connect it to the speaker outs inline and then run the left & right cables from the Cona to the your passive speakers.
Regards,
Theomaster
Vintage Bang & Olufsen
Thanks, are the Beovox Conas any good there's one on Ebay. They certainly look the part. Phil.
