Beocenter 7000 sub query
bigphil
Posts 69
Silver Member
bigphil Posted: Mon, Jul 7 2014 11:48 AM
Hi all can anyone tell me if its possible to connect a passive subwoofer to my 1980 Beocenter 7000 using the speaker outputs. Cheers Phil
the_o_master
Posts 856
Yes it is possible.
The way to make the passive sub (e.g. Beovox Cona) work with your BC7000 will be to connect it to the speaker outs inline and then run the left & right cables from the Cona to the your passive speakers.
Regards,
Theomaster
Vintage Bang & Olufsen
bigphil
Posts 69
Silver Member
bigphil replied on Mon, Jul 7 2014 6:21 PM
Thanks, are the Beovox Conas any good there's one on Ebay. They certainly look the part. Phil.
Page 1 of 1 (3 items) | RSS
