I just got the answer from Beocare regarding if BS5/BM5 will downscale 24-bit audio to 16-bit audio.
Now we know that there is no meaning of playing hi-res-soundtracks on the BS5/BM5. This is really bad, I think. THIS IS NOT A HIGH-END PRODUCT. Why dont they mention this on the "technical specs" on their website?
Read the answer below:
Hi Martin,
I am very sorry to have kept you waiting so long. I have been away on holiday and was not able to reply sooner.
I have checked with the Technical Product Manager for BeoSound 5 and he informed me that FLAC files will be downsampled to 44.1 kHz/16 bit if higher resolution.
I hope this answers your question - otherwise, do not hesitate to contact me again.
Kind regards,
Ina Bang Andersen (Ms) | Customer Service
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
This makes me think that my solution of using an Olive One with a first generation Beomaster 2000 and S45’s may be a much better high end option than I thought possible.
Graham
Might be - if you have some files in real 24/192 quality
Millemissen: Might be - if you have some files in real 24/192 quality MM
True enough! The BS 5 down samples to CD quality.
I have several Linn Studio Master downloads. I'll admit that I am just as likely to use the Olive One for internet radio as anything else. The high quality streams are better than CD.
Shame on you B&O!
