Beosound 5 - Support for FLAC 192khz/24-bit
This post has 44 Replies | 2 Followers
Sweden
Posts 357
Silver Member
Martin replied on Mon, Aug 18 2014 11:21 AM
I just got the answer from Beocare regarding if BS5/BM5 will downscale 24-bit audio to 16-bit audio.
Now we know that there is no meaning of playing hi-res-soundtracks on the BS5/BM5. This is really bad, I think. THIS IS NOT A HIGH-END PRODUCT. Why dont they mention this on the "technical specs" on their website?
Read the answer below:
Hi Martin,
I am very sorry to have kept you waiting so long. I have been away on holiday and was not able to reply sooner.
I have checked with the Technical Product Manager for BeoSound 5 and he informed me that FLAC files will be downsampled to 44.1 kHz/16 bit if higher resolution.
I hope this answers your question - otherwise, do not hesitate to contact me again.
Kind regards,
Ina Bang Andersen (Ms) | Customer Service
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only),  Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
vikinger replied on Mon, Aug 18 2014 11:56 AM
This makes me think that my solution of using an Olive One with a first generation  Beomaster 2000 and S45’s may be a much better high end option than I thought possible.
Graham
Millemissen
Flensborg, Denmark
Posts 14,680
Might be - if you have some files in real 24/192 quality Unsure
vikinger
Posts 5,422
vikinger replied on Mon, Aug 18 2014 2:05 PM
Millemissen:
True enough! The BS 5 down samples to CD quality.
I have several Linn Studio Master downloads. I'll admit that I am just as likely to use the Olive One for internet radio as anything else. The high quality streams are better than CD.
Graham
koning
holland
Posts 4,220
koning replied on Mon, Aug 18 2014 4:03 PM
Shame on you B&O!
Page 2 of 2 (45 items) < Previous 1 2 | RSS
