Hello Beoworld!
Can someone help me identify this component of a Beogram 3000, type 5228.
Click here for a slightly larger image (opens in new tab/window).
Thanks!
Welcome to Beoworld !
That is a record cleaner that someone stuck onto an otherwise nice Beogram.When I say it like this, it's because it's usually very difficult - if not impossible - to remove theremains of the sticky pad that holds it.Not original - and in my opinion good for not a lot.
Hey Dillen,
Thanks a lot for clarifying that!
From what you're saying, whether the record cleaner is useful or not, I'm assuming its safer to leave it as is compared to a making a mess by trying to remove it.
I guess I'll find out when I get the TT delivered (just bought it on eBay recently).
Cheers!
