MCL2P not powering up
madskp
Denmark
Posts 321
madskp Posted: Sun, May 6 2012 11:15 AM
I just acquired a MCL2P unit that I wan't to use for connecting a set of passive speakers to my BV8 40".
When I connect it I get the red standby light but when i turn on the TV the light stays red and there is no sound comming out of the speakers.
I have tried with two different powerlink cables with no difference.
It works fine when I connect a set of Beolab 4's
Anyone have a hint on what i might have overlooked? Or will this not work at all?
Magnus
Norway
Posts 331
Magnus replied on Sun, May 6 2012 11:19 AM
What type are your Powerlink cables? They must be mk. 2 to work with the Passive (mk. 3 will work with Beolab 4 but not the Passive).
Mk. 2 are fully wired, while mk. 1/3 are not.
If they have a triangel on the plug that means they are mk. 3.
Magnus
Vienna
make an educated guess
Posts 1,090
Vienna replied on Sun, May 6 2012 12:40 PM
As Magnus already mentioned - you need a FULLY MOUNTED = ALL 8 PINS WIRED PowerLink Cable.
There have been approx 10 different types of PoweLink-Cables over the last 25 years - most of them
have been discontinued.
Maybe your dealer has some of these discontinued FULLY MOUNTED PL cables (eg PoweLink MK2) still on stock.
If he has to order a new cable from B&O only two types out of all recent PL-Cables are suitable to connect a MCL2P:
B&O Order # 6271227 -  DIN 8pin<> DIN 8pin - 5 m  Black
B&O Order # 6271228 -  DIN 8pin<> DIN 8pin - 10 m Black
madskp
Denmark
Posts 321
madskp replied on Sun, May 6 2012 12:51 PM
Ok I got it to work with a cable i found in my basement, so I Guess that is an MK2 cable.
The wierd thing is that of the two other I tried the one had the triangle marking and must therefore be MK3 but the other was thicker and didn't have it.
I got bot of the very recently so I am a little in doubt what MK the one without the triangles are.
Anyway, the important thing is that its now working.
Thanks guys
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
