4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Beomaster 5 doesn't run Windows XP, it runs Windows XP Embedded which is a different product. Notably, it doesn't include Windows Update, and the idea is that the platform will remain stable and the product vendor will choose what updates to deploy (to avoid the product from stopping to work unexpectedly due to some update, among other things).
http://redmondmag.com/articles/2014/02/19/windows-xp-embedded-support.aspx
Having said that - no, I don't know if B&O actually has pushed SP3 to those Beomasters.
--mika
Hi olvisab,
in the BM5 B&O use/d the 'embedded' version, which is still supported (untill jan 2016).
you can try to install SP3 by yourself like shown by BeoIce in his great thread here.I did it myself on my BeoMedia1 and it works flawlessly if you proceed like shown there.
After applying XP SP3 you can try to install iTunes If all gets messed up just restore your BeoMaster 5 as you did before and everything is fine except you can't use it for restore of your iPhone.
Ralph-Marcus
2 quick questions :
Is it possible to increase the RAM on the BM5 ? If yes, do you think it can be a good trick ?
