Beomaster 5 still in xp sp2, why?
This post has 6 Replies | 2 Followers
olvisab
Posts 1,391
olvisab Posted: Thu, Jul 24 2014 7:24 PM
Hi
I have restored the bm5 few months ago and today I wanted to install an app that needs xp sp3.
I am surprised that my windows is not up to date.
I have checked the automatic update, I thought it includes microsoft updates.
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
tournedos
Finland
Posts 7,357
tournedos replied on Thu, Jul 24 2014 7:56 PM
Beomaster 5 doesn't run Windows XP, it runs Windows XP Embedded which is a different product. Notably, it doesn't include Windows Update, and the idea is that the platform will remain stable and the product vendor will choose what updates to deploy (to avoid the product from stopping to work unexpectedly due to some update, among other things).
http://redmondmag.com/articles/2014/02/19/windows-xp-embedded-support.aspx
Having said that - no, I don't know if B&O actually has pushed SP3 to those Beomasters.
--mika
Millemissen
Flensborg, Denmark
Posts 14,680
Hi olvisab,
in the BM5 B&O use/d the 'embedded' version, which is still supported (untill jan 2016).
olvisab
Posts 1,391
olvisab replied on Thu, Jul 24 2014 8:46 PM
Thanks for your explanation.
I wanted to install itunes on it. I just need it in order to restore my iphone.
Ok this is not the best choice but I don't have any windows pc or mac on hand actually.
RaMaBo
near Munich
Posts 626
RaMaBo replied on Fri, Jul 25 2014 10:55 AM
you can try to install SP3 by yourself like shown by BeoIce in his great thread here.I did it myself on my BeoMedia1 and it works flawlessly if you proceed like shown there.
After applying XP SP3 you can try to install iTunes  If all gets messed up just restore your BeoMaster 5 as you did before and everything is fine except you can't use it for restore of your iPhone.
Ralph-Marcus
olvisab
Posts 1,391
olvisab replied on Fri, Jul 25 2014 12:01 PM
Hi ramabo,
Thanks for the tip.
This evening I will try with a windows pc before messing up my bm5.
It would probably work but if I have a chance to avoid a restoration, I take itWink
Steph
France
Posts 1,059
Steph replied on Fri, Jul 25 2014 3:24 PM
2 quick questions :
Is it possible to increase the RAM on the BM5 ? If yes, do you think it can be a good trick ?
Page 1 of 1 (7 items) | RSS
