Would someone please remind me how to program this combination so that it does not switch the whole link system off when putting the attached TV to standby?
David
I think that the LX5500 should be in Option 2, so press: STBY, PICTURE, 2, STORE on the BL1000. Hope this works!
TV is already in option 2!
I remember that old LX/MX Beovisions can be set to rare options (V.OPT) like 2.6 , 2.5 , 1.5....
I would try V.OPT 2.6. Press PICTURE 2 STORE 6 STORE.
Hope this helps.
Stefan
Thank you for the reply Stefan. These all work but do not correct the situation. The config guide says option 2 but has no mention of additional options to prevent entire link system standby.
Have you downloaded the manuals on here - a link!
Peter
Thank you for the link. Page 15 of the MCL2 installation guide gives details of programming the MCL2AV standby function but these depend on a sensor being attached and holding the timer button. It does not appear possible to do this without the sensor (I use the LX TV only) so I need to obtain one of these.
