Fantastic, looking forward to "see" it. My dealer in DK had last week not even got any information about the products expected delivery date nor the price.
That is really strange.
Keep posting ;-)
lano:Any link to software or user manuals?
Any pictures of the installation (hardware) would be very nice to see. I am very curious.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Michael:Any pictures of the installation (hardware) would be very nice to see. I am very curious.
Hi there
Any updates I cannot wait to see the updates and how this works.
Eclipse 65V1-32Beosound M5Essence MK2BLI
... what are you going to connect it to? Which device you're planning to control?
Beoworld app with direct photo upload and emoticons.
PhilLondon:... what are you going to connect it to? Which device you're planning to control?
No screenshots?
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Do you configure 3rd party products in the same way as with MLGW?
How does it work with both ML and NL products together?
mjmedlo:What screen shots would you like to see?
I`d like to see some screenshots of the web interface, especially the page(s), where you create macros - as Beo said, you can program it "on the fly".
Also I`d like to know more about differences between MLGW and BLGW. You said they are using the same app, so, there can`t be many differences.
What about two-way communication? When I change LIGHT levels using Beo4/6, my 3rd-party-home automation ipad/iphone app will display the changes light levels (same with curtains control - it will even display the positions (100% closed - 60% closed....).
That`s what the MLGW can`t do. Is that possible with BLGW?
Regarding hardware: MLGW has one RS232 connection, one ML socket, an ethernt socket and mains plug. Same as BLGW?
You can install the MLGW into a professional 19" rack. BLGW is another box - is it possible to build it into a rack? Maybe with additional brackets?
I couldn`t find a user manual or an installation guide (even not on Beoworld...;)) Do you have a link or a pdf that you can send to Lee or Peter for the Beoworld-manuals-section?
Sorry for so many questions, but I think the BLGW is a very interesting product (as the MLGW is), and it seems that many people are eager to learn mor about it.
Thanks in advance for your time.
Stefan
Received my Beolink Gateway last night. Only just started to set it up but the interface is much cleaner than the old one but does take a little bit of getting used to. So far only just added rooms and assigned the products to them. For Network link products its very easy, turned on my BV11 and the gateway finds it straight away plus reads the sources from it and sets them up for you. Didn’t quite get it perfect and doesn’t seem to have Webmedia support. Masterlink products again, turn them on and the gateway find them and you simple add them to a room. However, you have to configure the sources manually. Still very simple to do.
Haven't tried to create any lighting scenes yet but plan to try over the weekend. In terms of look and feel, its very different from the old MLGW. The unit is about 30cm long and 15cm wide, 5-10cm deep (sorry I'm guessing here). The back is white plastic but the front is a single piece of aluminium with the B&O logo on it. Doesn’t look like it's rack mountable but does have four screw holes in the back so guessing there is a wall mount bracket available, but it wasn't supplied.
In terms of connections, it has standard 2-pin B&O power connector, 2 USB ports for RS232 connectors, two RJ45 connectors, one for networklink and the other for masterlink, plus a traditional masterlink connector. I use Lexcom Home for distributing the masterlink signals around the home and so just plugged a Cat7 cable into the RJ45 masterlink socket and it worked like a dream. Nice not to have to use the clunky large masterlink plugs
Thanks a lot, sounds very interesting.
Funny that we dont hear/read more about the product from B&O HQ.
I wonder.
"Funny that we dont hear/read more about the product from B&O HQ".
Here it is, Beolion :
BeoLink Gateway
Steph: "Funny that we dont hear/read more about the product from B&O HQ". Here it is, Beolion : BeoLink Gateway
Thanks, but there is still only references and manuals for the old MLGW in their homepage. Strange :-)
mjmedlo:I have finally obtained te electronic copy of the installation and programming guide. Shoot me an email and I'll send it over to all who are interested. Mjmedlo. AT M. E dot. Com
I send you a pm - thanks.
I sent you un email
thanks
mjmedlo:I only use the app. Can you email me?
Can you email me?
Thanks for the install guide! Interesting stuff - exactly what we need to learn more about the BLGW.
I`ve sent the pdf to Lee - hopefully the guide is available soon in Beoworld`s manuals section....
BTW: I thought there are more differences between MLGW and BLGW....
Does anybody know who made the software? MLGW was made by Ikatu, as far as I know.
Will the new gateway work with things like teh Philips Hue lighting and Lutron GRX?
Toby
@mjmedio
A bit off-topic, but...
.... I am just curious, so pardon me for asking.
What is the setting 'HIS VANITY' supposed to mean
WC, BEDROOM, THEATER, GLOBAL and the others I do understand.
Must have something to do with BATH.
maybe his dressing room
malcolm
In the U.S., the vanity would mean the lights around a mirror, typically in the bathroom or bedroom, usually over the sink.
Millemissen: @mjmedio A bit off-topic, but... .... I am just curious, so pardon me for asking. What is the setting 'HIS VANITY' supposed to mean WC, BEDROOM, THEATER, GLOBAL and the others I do understand. Must have something to do with BATH. MM
badgersurf: Hi, Will the new gateway work with things like teh Philips Hue lighting and Lutron GRX? Thanks Toby
The Philips Hue would be very difficult to use with a driver, due to its high degree of customization. Henrik from B&O and I have written custom strings to achieve the control with the MLGW, which works brilliantly. I have even found ways to control full scenes and program them into the Beo6 with the scene image. Search the forum for my posts on this.
@beojeff
Thanks - I learned something new today
Googling gave me nothing, but a T.S. Eliot quote.
Millemissen:@mjmedio A bit off-topic, but... .... I am just curious, so pardon me for asking. What is the setting 'HIS VANITY' supposed to mean WC, BEDROOM, THEATER, GLOBAL and the others I do understand. Must have something to do with BATH. MM There is a tv - and there is a BV.
Mystery solved - thanks.
Hello all
does anyone know the UK RRP for the gateway.
my system is all ML and I would love to be able to control the other rooms from my lounge.
cheers
Seanie_230:Hello all does anyone know the UK RRP for the gateway. my system is all ML and I would love to be able to control the other rooms from my lounge. cheers Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
I want to be able to turn down the TV in my bedroom from the lounge or be able to turn on music in the bathroom from the kitchen etc.
I also want to link my system to my iLight system in the lounge if this is possible.
thank you
Is there any information about the Beolink Gateway on the officielt B&O homepage?
Can't really find it :-(
I dont want to buy the old MLGW if a new one is there?
Does anyone know what the difference is between the new and old Gateway solution?Just in case I get a really good offer for the old MLGW.
