Beolink gsteway received
This post has 45 Replies | 9 Followers
mjmedlo
Posts 922
mjmedlo Posted: Mon, Aug 4 2014 10:07 PM
Mates
I've just received my BLGW.
Will keep updates posted!
MJM
beolion
Posts 485
beolion replied on Mon, Aug 4 2014 10:21 PM
Fantastic, looking forward to "see" it. My dealer in DK had last week not even got any information about the products expected delivery date nor the price.
That is really strange.
Keep posting ;-)
lano
Posts 161
lano replied on Mon, Aug 4 2014 11:07 PM
Any link to software or user manuals?
mjmedlo
Posts 922
mjmedlo replied on Tue, Aug 5 2014 2:53 AM
lano:
The boom that comes with it is of course no help.
I'll see if I can find the reference manual with set up info
mjmedlo
Posts 922
mjmedlo replied on Tue, Aug 5 2014 2:57 AM
I find the web panel to be very nice.
I only had a chance to add a couple lighting zones
So far I see the web panel and programming differences.
As far as I can tell the beolink app is unchanged.
It's like learning a new language but seems to be nice with the two way on the web panel.
Very promising of what's to come.
I'll try to capture a couple screen shots
Michael
Sweden
Posts 2,578
Michael replied on Wed, Aug 6 2014 11:59 AM
Any pictures of the installation (hardware) would be very nice to see. I am very curious.
mjmedlo
Posts 922
mjmedlo replied on Wed, Aug 6 2014 8:24 PM
Michael:
I'll make a run at this tonight.
The box itself is the exact same as the nl/ml gateway. The hardware is no different.
The interaction is nice though.
Seanie_230
UK
Posts 2,278
Hi there
Any updates I cannot wait to see the updates and how this works.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
PhilLondon
London
Posts 3,637
... what are you going to connect it to? Which device you're planning to control?
Beoworld app with direct photo upload and emoticons.
mjmedlo
Posts 922
mjmedlo replied on Fri, Aug 8 2014 4:14 AM
PhilLondon:
The app is the same.
I have it connected to a radiora 2 system.
beolion
Posts 485
beolion replied on Mon, Aug 11 2014 10:17 PM
No screenshots?
olvisab
Posts 1,391
olvisab replied on Mon, Aug 11 2014 10:32 PM
The app is the same
That´s logical. Pretty good since the last update
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
mjmedlo
Posts 922
mjmedlo replied on Tue, Aug 12 2014 2:21 AM
What screen shots would you like to see?
beolion
Posts 485
beolion replied on Tue, Aug 12 2014 9:06 AM
Do you configure 3rd party products in the same way as with MLGW?
How does it work with both ML and NL products together?
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Aug 12 2014 12:58 PM
mjmedlo:
I`d like to see some screenshots of the web interface, especially the page(s), where you create macros - as Beo said, you can program it "on the fly".
Also I`d like to know more about differences between MLGW and BLGW. You said they are using the same app, so, there can`t be many differences.
What about two-way communication? When I change LIGHT levels using Beo4/6, my 3rd-party-home automation ipad/iphone app will display the changes light levels (same with curtains control - it will even display the positions (100% closed  - 60% closed....).
That`s what the MLGW can`t do. Is that possible with BLGW?
Regarding hardware: MLGW has one RS232 connection, one ML socket, an ethernt socket and mains plug. Same as BLGW?
You can install the MLGW into a professional 19" rack. BLGW is another box - is it possible to build it into a rack? Maybe with additional brackets?
I couldn`t find a user manual or an installation guide (even not on Beoworld...;)) Do you have a link or a pdf that you can send to Lee or Peter for the Beoworld-manuals-section?
Sorry for so many questions, but I think the BLGW is a very interesting product (as the MLGW is), and it seems that many people are eager to learn mor about it.
Thanks in advance for your time.
Stefan
Steven_London
Posts 51
Received my Beolink Gateway last night. Only just started to set it up but the interface is much cleaner than the old one but does take a little bit of getting used to. So far only just added rooms and assigned the products to them. For Network link products its very easy, turned on my BV11 and the gateway finds it straight away plus reads the sources from it and sets them up for you. Didn’t quite get it perfect and doesn’t seem to have Webmedia support. Masterlink products again, turn them on and the gateway find them and you simple add them to a room. However, you have to configure the sources manually. Still very simple to do.
Haven't tried to create any lighting scenes yet but plan to try over the weekend. In terms of look and feel, its very different from the old MLGW. The unit is about 30cm long and 15cm wide, 5-10cm deep (sorry I'm guessing here). The back is white plastic but the front is a single piece of aluminium with the B&O logo on it. Doesn’t look like it's rack mountable but does have four screw holes in the back so guessing there is a wall mount bracket available, but it wasn't supplied.
In terms of connections, it has standard 2-pin B&O power connector, 2 USB ports for RS232 connectors, two RJ45 connectors, one for networklink and the other for masterlink, plus a traditional masterlink connector. I use Lexcom Home for distributing the masterlink signals around the home and so just plugged a Cat7 cable into the RJ45 masterlink socket and it worked like a dream. Nice not to have to use the clunky large masterlink plugs
beolion
Posts 485
beolion replied on Fri, Aug 15 2014 11:00 AM
Thanks a lot, sounds very interesting.
Funny that we dont hear/read more about the product from B&O HQ.
I wonder.
mjmedlo
Posts 922
mjmedlo replied on Fri, Aug 15 2014 9:57 PM
Indeed it takes getting used too.
The names are now different.
Now you have resources to fill in.
And rooms can have sub parts... Which is kind of nice
Steph
France
Posts 1,059
Steph replied on Sat, Aug 16 2014 7:22 AM
"Funny that we dont hear/read more about the product from B&O HQ".
Here it is, Beolion :  Wink
BeoLink Gateway
mjmedlo
Posts 922
mjmedlo replied on Sat, Aug 16 2014 12:56 PM
I have finally obtained te electronic copy of the installation and programming guide.
Shoot me an email and I'll send it over to all who are interested.
Mjmedlo. AT M. E dot. Com
beolion
Posts 485
beolion replied on Sat, Aug 16 2014 6:57 PM
Steph:
BeoLink Gateway
Thanks, but there is still only references and manuals for the old MLGW in their homepage. Strange :-)
stefan
Posts 2,920
stefan replied on Sat, Aug 16 2014 7:54 PM
mjmedlo:
I send you a pm - thanks.
Stefan
mjmedlo
Posts 922
mjmedlo replied on Sat, Aug 16 2014 8:21 PM
I only use the app.
Can you email me?
claudiu
copenhagen
Posts 193
I sent you un email
thanks
stefan
Posts 2,920
stefan replied on Sun, Aug 17 2014 9:03 AM
mjmedlo:
I only use the app.
Can you email me?
Thanks for the install guide! Interesting stuff - exactly what we need to learn more about the BLGW.
I`ve sent the pdf to Lee - hopefully the guide is available soon in Beoworld`s manuals section....
BTW: I thought there are more differences between MLGW and BLGW....
Does anybody know who made the software? MLGW was made by Ikatu, as far as I know.
Stefan
lano
Posts 161
lano replied on Sun, Aug 17 2014 1:01 PM
Interesting reading, especially regarding custom drivers and two-way comminication. Does anybody have some information regarding the two-way cababilities? Can the web panel display what channel a ML connected TV is set to? Can it show the song playing on BS5? Can it show the channel a NL tv is set to?
I asume it can show temperature and dimmer settings if the connected home system can handle it. Anybody that has tried this?
mjmedlo
Posts 922
mjmedlo replied on Sun, Aug 17 2014 1:34 PM
The web panel gives no info on the beolink status. Only the environmental .... Ie lutron
mjmedlo
Posts 922
mjmedlo replied on Sun, Aug 17 2014 1:49 PM
Here are a couple of pics from the webpanel captured on my iPhone.
badgersurf
Posts 539
badgersurf replied on Mon, Aug 18 2014 12:16 PM
Will the new gateway work with things like teh Philips Hue lighting and Lutron GRX?
Toby
Millemissen
Flensborg, Denmark
Posts 14,680
@mjmedio
A bit off-topic, but...
.... I am just curious, so pardon me for asking.
What is the setting 'HIS VANITY' supposed to mean Confused
WC, BEDROOM, THEATER, GLOBAL and the others I do understand.
Must have something to do with BATH.
malcolm welborn
canary islands
Posts 188
maybe his dressing room
malcolm
beojeff
USA
Posts 2,012
beojeff replied on Mon, Aug 18 2014 12:55 PM
In the U.S., the vanity would mean the lights around a mirror, typically in the bathroom or bedroom, usually over the sink.
Millemissen:
@mjmedio
beojeff
USA
Posts 2,012
beojeff replied on Mon, Aug 18 2014 12:59 PM
badgersurf:
Toby
The Philips Hue would be very difficult to use with a driver, due to its high degree of customization. Henrik from B&O and I have written custom strings to achieve the control with the MLGW, which works brilliantly. I have even found ways to control full scenes and program them into the Beo6 with the scene image. Search the forum for my posts on this.
Millemissen
Flensborg, Denmark
Posts 14,680
@beojeff
Thanks - I learned something new today Smile
Googling gave me nothing, but a T.S. Eliot quote.
mjmedlo
Posts 922
mjmedlo replied on Mon, Aug 18 2014 4:12 PM
Millemissen:
@mjmedio
It's a his and hers light over separate bathroom sinks. Wink
Millemissen
Flensborg, Denmark
Posts 14,680
Mystery solved - thanks.
Seanie_230
UK
Posts 2,278
Hello all
does anyone know the UK RRP for the gateway.
my system is all ML and I would love to be able to control the other rooms from my lounge.
cheers
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
olvisab
Posts 1,391
olvisab replied on Mon, Aug 18 2014 10:14 PM
Seanie_230:
Hello all
cheers
Beovision 7 MKIV (Blu Ray) Beolab 9 Beolab 6000 Beo 4 Beocenter 9300 Apple TV SKY HD Optoma HD65 Projector Lintronic TT455-RT-238 Beovision 3 MKII
I don't see the interest for you to control the other room if you have only video ml products.
If you have a beomaster 5, then you can really see what song is playing (already 2 way with the old MLGW).
Maybe you can look at your tv through walls Smile
You probably have a good reason.
Seanie_230
UK
Posts 2,278
Hi there
I want to be able to turn down the TV in my bedroom from the lounge or be able to turn on music in the bathroom from the kitchen etc.
I also want to link my system to my iLight system in the lounge if this is possible.
thank you
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beolion
Posts 485
beolion replied on Sun, Oct 19 2014 5:39 PM
Is there any information about the Beolink Gateway on the officielt B&O homepage?
Can't really find it :-(
I dont want to buy the old MLGW if a new one is there?
Does anyone know what the difference is between the new and old Gateway solution?
Just in case I get a really good offer for the old MLGW.
Page 1 of 2 (46 items) 1 2 Next > | RSS
